weak heat
Old Apr 1, 2008 | 12:48 AM
05windviel's Avatar
05windviel
Default weak heat
well i don't know if its normal or not and not sure if its bad but everything in terms of my heater/defrost/air isn't coming out very strong you can't even really feel anything. what should i do about this if its not normal
Old Apr 1, 2008 | 12:52 AM
Favre4TD's Avatar
Favre4TD
Default RE: weak heat
no airflow or no heat?
Rhino77's Avatar
Rhino77
I don't think that is normal, my heat comes out pretty strong. However the air conditioning in heat over 95+ isn't rather lacking.
Old Apr 1, 2008 | 12:54 AM
05windviel's Avatar
05windviel
well i feel a slight flow of air like if you were to breathe normal and put your hand infront of your face otherwise it might as well be nothing
Old Apr 1, 2008 | 01:00 AM
Favre4TD's Avatar
Favre4TD
live in a winter place? ice or some stuff cloggong the intake to the heater vents?
Old Apr 1, 2008 | 01:03 AM
danbevsv6rumbler's Avatar
danbevsv6rumbler
have you checked your cabin filter? when i bought my car i wasn't sure if it had been replaced at its last inspection by ford... but if it was that filter got dirty real fast because i would have replaced it only 5000 miles later...
Old Apr 1, 2008 | 01:21 AM
Favre4TD's Avatar
Favre4TD
Just lower the top!
Old Apr 1, 2008 | 09:59 AM
157dB's Avatar
157dB
Cut & Paste Expert
No airflow or no heat but lots of cold air.
Could be the plenium motor gone bad.
Need more info here to diagnose the problem.
Old Apr 1, 2008 | 03:57 PM
bigdaddy0987's Avatar
bigdaddy0987
does it do it on all settings really just take it to the dealership they will diagnose the problem you dont have to have them do the work if it only does it on lower settings it could be a blower motor resistor
[/align]
Old Apr 1, 2008 | 04:09 PM
MustangNick16's Avatar
MustangNick16
i had this same poblem well i still do. when only defrost is on is the hot air also blowing down by your feet, i took my car in several times and it still has not been fixed
