Got a little Drone problem
Old May 20, 2008 | 08:19 PM
BWfVA's Avatar
BWfVA
Default Got a little Drone problem
Ok I got me a set of Flowmaster Super 40's put on the other day and they sound great, but I have a considerable amount of drone in it. If I am not mistakin I either read it on here or in a Chevy High Proformance mag. that drone is caused but the mufflers making th same sound at the same time.
Anyways, I am looking for something that wont kill the sound outside of the car but will kill some of the interior drone down. I was thinking that a H pipe would change the flow characteristics just enough to kill it down, cause a little drone is fine, and it might take away some of the ricieness.
Any solutions I am open to them
Old May 20, 2008 | 09:10 PM
raubt's Avatar
raubt
Default RE: Got a little Drone problem
What pipes do you have now? Straight back? I had an H with my Borla Stinger duals and it made a fair bit of drone. I've since switched to an X and the drone isn't as bad as with the H, but still there at certain RPMs.
You could also put new gears on so you get a little more pep out of your car as well as change the RPM that you cruise at, which should get rid of the drone.
Or you could talk to your muffler place about putting resonators on (they're welded into the pipes shortly after the cats I believe) which will get rid of most/all of the drone.
Either of those last two options will minimize/eliminate the drone and not mess with how the mufflers sound on the outside (Although changing the gearing would probably make them louder on the outside when you're cruising because the RPM would be higher).
Old May 21, 2008 | 12:35 AM
Maverickaf17's Avatar
Maverickaf17
How much do those cost usually?
Old May 21, 2008 | 01:19 AM
project85's Avatar
project85
I'd try 14" magnaflow resonators to tone some drone out...
Magnaflow 10416
Old May 21, 2008 | 10:46 PM
BWfVA's Avatar
BWfVA
I have always heard to stager some resonators that should kill the drone completely, but I have it just staight back so I figure since its a little high pitched anyway I would put on a H pipe and that would help some and then put on some High flow cats which would also change the flow pattern some, maybe even have them stagerthe cats, but I dont wanna kill the outside noise to much cause its just about right, A gear is outta the question, I am not a big fan of gears anyways I like the stock gears setup pretty well for the driving I do and the car drones at 1600, 2000 to about 2200 or so, so it is really a multirange drone
Thanks Keep them coming
Old May 22, 2008 | 07:25 AM
Wishbone's Avatar
Wishbone
Flowmasters just drone. No 2 ways about it. That and stainless steel is the reason I went with Bassani.
Old May 22, 2008 | 08:43 AM
AmericanICON's Avatar
AmericanICON
ORIGINAL: project85
Magnaflow 10416
An H pipe would definitely make it sound better than running straight pipes. (I know because I've been there.) Running an H pipe would not improve your drone situation.
A resonator would definitely help with the drone issue. You could mount two of these in front of the axle-- like a mid muffler system.
That's actually what I have--2 Magnaflow glasspacks, mounted in front of the axle, with an H pipe, and it sounds great. No drone!
http://www.youtube.com/watch?v=dYpzoFgHObQ
Old May 22, 2008 | 10:45 PM
BWfVA's Avatar
BWfVA
Well I have had Flows on other Vehicles, wehave a truck with a LT1 and FlowBigBlock 50 series on it and it doesnt seem to drone very much, plus I think it was just were I wasnt used to it, I am still thinking about putting in the H pipe for a throater sound, the reason I didint go with something else is I dont want something so loud that the law is not going to like it, or else I think atleast I would have went with SLP loudmouths, but VA is still a communist state when it comes to cars so I am stuck with what the big man will let you by with. If it gets to bad I guess I will have them put in some resonators but I dont want to kill the sound it already makes
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Sep 10, 2015 08:39 PM
