MGW short shifter
Old Jun 26, 2008 | 12:36 AM
vb101's Avatar
vb101
Default RE: MGW short shifter
Shift stops are not necessary since the T5 has built in shift stops. I have an MGW and after two weeks it's much smoother than the Hurst I had before and makes no noise at all. As a matter of fact it shifts more smoothy than it did stock and with about 25% shorter throw at that.
Old Jun 26, 2008 | 01:04 AM
NocturnalV6's Avatar
NocturnalV6
I would hope that MGW would shift better than stock lol. No like trying to shift a crowbar through bricks
Old Jun 27, 2008 | 07:26 PM
vancebreck's Avatar
vancebreck
Like most of the others the hardest time I had was removing the old shifter. I have mine set to 7 turns and I like it.
The only thing I would stress is the point in the instuction where it talks about the shifter pivoting freely with the transmission (step 6). It was strange at first. Just after shifting gears I can feel the shifteralmost surging back and forth. I called George cause I was concerned I F'd something up. That is the movement the was speaking about.
Good luck on the install. Did you get a new shift **** as well or stick with the stock ****?
Old Jun 28, 2008 | 03:30 PM
WeMowMuppets's Avatar
WeMowMuppets
I stuck with the stock shift **** for know. What about you.
Old Jun 28, 2008 | 07:33 PM
vancebreck's Avatar
vancebreck
I started with the stock then got tired of it in about 2 days. Went ahead and upgraded to the MGW black classic ball assembly with the satin chrome (just like the pic on their website). Looks much better I think.
firehorse02
Nov 16, 2015 11:28 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Explosive
Oct 2, 2015 07:45 AM
guitarman376
Sep 30, 2015 05:54 PM
junior04
Sep 28, 2015 10:53 AM
