harmonic Balancer
Old Jul 27, 2008 | 01:19 PM
dcsimons's Avatar
dcsimons
Default harmonic Balancer
has anyone herd of or had problem with harmonic Balancer on 05 v6 failing
Old Jul 27, 2008 | 05:44 PM
dcsimons's Avatar
dcsimons
Default RE: harmonic Balancer
ok here some more info my wife told me her 05 (v6)has been making a chirping noise from motor when cold , today she told me it as doing it all the time now so when i waschecking the belt i notice a small pice of rubber on the harmonic Balancer so i marked the two half and started the car ran the car for about a min. the two marks were now 180 apart , this car has 50,000 miles on it,if it would have come apart i would be changing more then just a harmonic Balancerso yall need to check yours harmonic Balancer
Old Jul 28, 2008 | 10:33 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Sounds more like the belt is slipping.
Old Jul 28, 2008 | 11:54 AM
Yellow Tang's Avatar
Yellow Tang
Water Pump? Have you checked it
Old Jul 28, 2008 | 12:39 PM
Lethaldosage423's Avatar
Lethaldosage423
start with the easy.. Get a new belt, your one sounds like its stretching when its hot. When the belt is off check the allignment of the harmonic balancer, i.e. if it feels loose or if you notice an imperfection in it. If it is loose try tightening it but if thats not working its time for a new one
Old Jul 28, 2008 | 05:29 PM
dcsimons's Avatar
dcsimons
harmonic Balancer is coming apart did you not read my post
Old Jul 28, 2008 | 05:41 PM
05AV6's Avatar
05AV6
If the inner hub and outer ring have moved 180 degrees apart, then we may all have a problem in the making. Slipping of the inertia ring is not a good thing. Thanks for the heads up, I'll be marking mine immediately.
Old Jul 28, 2008 | 07:38 PM
ODDYSEY's Avatar
ODDYSEY
ORIGINAL: dcsimons
Now that makes me want to help....
Old Jul 28, 2008 | 07:46 PM
shb5007's Avatar
shb5007
ORIGINAL: ODDYSEY
ORIGINAL: dcsimons
Yea, people are always so nice on MF...
Old Jul 28, 2008 | 08:48 PM
dcsimons's Avatar
dcsimons
yea i was trying to warn people of a problem and you tell me to check my belt when the harmonic Balancer is coming apart if yall dont want warning i am sorry
