nos
Old May 12, 2005 | 11:06 PM
quickstang05's Avatar
quickstang05
Default nos
What are the nos kits that work best with the mustang???? Im looking into getting one.
Old May 13, 2005 | 11:38 AM
StupidTodd's Avatar
StupidTodd
Default RE: nos
If you have the V6 (which I'm guessing you do, since you posted in the V6 section)... I wouldn't go anything over a 50 shot until you rebuild your internals...
I run a 25-40 shot, using the Sneaky Pete System from NOS. The bottle is relatively small (holds like 1.2 lbs of nitrous, or something like that), and can be fit neatly up under the dash... it's a small bottle, so you really don't have the fire/explosion worry...
The only problem I have with the system, is how quickly I go through it... I am definitely planning on going with a larger trunk mounted bottle in the near future, but that's just so I don't run out...
Unless you plan on doing the forged internals thing... I'd say just go with any dry system, mount it into your intake and you'll be fine... I don't see a real point in doing a wet system install if you're not going to be using higher than a 50 shot.
Old May 13, 2005 | 04:07 PM
quickstang05
Default RE: nos
i have no mods on there now, what other mods should i get.
and how much of a boost does that give you.
Old May 16, 2005 | 11:20 AM
StupidTodd's Avatar
StupidTodd
Default RE: nos
how much boost? well a 25 shot gives you about 25 horsepower... a 40 shot gives you about 40 horsepower... (so basically 10-20% increase)
What other mods should you get? - Search the forums on this one. There are too many to simply list. What you do is up too you.
If you REALLY want to make this a fast car, start by making yourself a plan. List everything you want to do to the car (whether it is currently available or not) and start thinking about the order things need to go in. Work out different stages that all need done together.
For example, my next few steps will be: Having Dual Exhaust run, changing out the K&N for a CAI (not sure which yet), and replacing the sneaky pete nitrous system with a larger bottle (that 1 lb bottle runs out too quickly), then I'm off for a dyno tune. That will be followed by swapping my gears out for the 4.10's and adding the trak-lock rear end. I could keep going, but I think that gives you the general idea. Figure out how far you want to go, and then make a plan to get there.
Oh, and FYI - don't call it NOS, it's N2O, NOS is Nitrous Oxide Systems (a company that makes nitrous stuff), the gas is actually called N2O.
Lee1911
Sep 1, 2015 02:12 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
kevin02
Mar 31, 2004 02:59 AM
Ian70mustang
Mar 19, 2004 03:14 AM
5ohgirl
Nov 17, 2003 01:54 AM
