clunky drivetrain solution!
Old Aug 21, 2008 | 05:47 AM
jetking69's Avatar
jetking69
Default clunky drivetrain solution!
Theres a bunch of threads about this; and pretty much the consensus is that its normal. So, i figured the slack in my drivetrain was normal.
I just got my car back from service, and i had complained about an odd light clanging noise i occasionally get from under the car in the mornings. Long story short, they couldn't figure it out but they removed the driveshaft and reinstalled it in really tight to see if it would help; i talked to the mechanic and he said he torqued all the bolts down real good and used locktite.
The second i drove off the lot i noticed the entire driveline felt ridiculously smoother and tighter. The difference in the 1-2 shift is like night and day. So basically, this entire time all my car needed was a little tightening up.
Thought this might be interesting to all you guys who figured the clunkiness was just the way the car is.
btw my car is a 07 v6 stick, all stock.
Old Aug 21, 2008 | 07:07 PM
Dean Martin's Avatar
Dean Martin
Anyone know what the correct torque is for these bolts? Curious to check mine.
Thanks.
Old Aug 23, 2008 | 05:23 PM
157dB's Avatar
157dB
Cut & Paste Expert
76 Ft Lbs
I also has the ting ting sound and my front driveshaft
bolts were also loose at only 2K miles on the odometer.
Seems like a pretty common problem.
Old Sep 6, 2008 | 04:34 PM
tn_gt's Avatar
tn_gt
srry to bring up an old thread, but has anybody else done this and it work?
Old Sep 6, 2008 | 09:17 PM
jahudso2's Avatar
jahudso2
Yes I would also like to know if this works. Also which driveshaft bolts are they? The ones that connect to the tranny, or the ones that connect the two pieces in the middle?
Old Sep 6, 2008 | 09:31 PM
red07Pony's Avatar
red07Pony
count me in for wanting to know. I've got a stock '07 manual tranny and I get the clunky noise often. So please, do tell
Old Sep 8, 2008 | 02:44 PM
jahudso2's Avatar
jahudso2
anyone else tighten up their driveshaft?
Old Sep 8, 2008 | 04:14 PM
157dB's Avatar
157dB
Cut & Paste Expert
Its on the V6 one piece driveshaft.
Its the tranny to driveshaft bolts.
12 point metric suckers.
fastbackford351
Oct 1, 2015 12:24 PM
Sep 17, 2015 07:32 PM
rksnow1
Sep 14, 2015 08:46 PM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
