Rear Shocks
Old Oct 16, 2008 | 01:50 PM
ottawapony's Avatar
ottawapony
Default Rear Shocks
I have a 2005 Mustang. I have replaced the rear springs with roush rear lowering springs about a year now. I am starting to hear a thumping noise everytime I go over a bump. Does this sound like rear shocks? If so what should I replace them with (aftermarket)
Old Oct 16, 2008 | 02:42 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
I would recommend replacing the factory shocks/struts if you have aftermarket springs.
Old Oct 17, 2008 | 09:16 AM
157dB's Avatar
157dB
Cut & Paste Expert
I have the matching Roush rear shocks.
The OEMs wear out rapidly after a lowering
spring installation. Worn out shocks dont 'pop'.
I would first check for proper orientation of the springs.
The spring pig should rest where the OEM spring
pig did and you should be able to read 'ROUSH'
on the spring without standing on your head.
Did you cut your bump stops when you did the spring install?
Old Oct 17, 2008 | 01:05 PM
ottawapony's Avatar
ottawapony
Thanks
I will get the rear springs and shocks checked. Any other suggestions on after market rear shocks?
Old Oct 17, 2008 | 01:26 PM
danbevsv6rumbler's Avatar
danbevsv6rumbler
i run tokico shocks/struts
they've held up fine the 5500 i've had them on haha. in all seriousness though they're great shocks
Old Oct 17, 2008 | 01:56 PM
scorpio333's Avatar
scorpio333
Are those HP or D Specs?
I have the Roush springs sitting on the bench and plaaned to throw them on while replacing the rearend. The plan was to go with the OEM shocks for a bit. I had Koni adjustables on a previous car and honestly the adjustable part seemed to be a waste, basically I only used them for seasonal temperature differences. For that reason I was leaning towards the Roush or HP's and the HP's are a bit cheaper.
Old Oct 17, 2008 | 02:15 PM
ODDYSEY's Avatar
ODDYSEY
I have the tokico d-specs and the adjustable part was a life savers for me, since i run wide staggered wheels in the rear, I set the adj. rears to stiff so they rubber wouldn't rub on the fenders.
Old Oct 20, 2008 | 08:24 AM
ottawapony's Avatar
ottawapony
I noticed the word Roush on the springs is upside down . Were the springs installed wrong and if so can I change them around to wear the word Roush reads straight up?
Any info on installing these spring properly.
Hope it's not too late!!
Old Oct 20, 2008 | 11:33 AM
157dB's Avatar
157dB
Cut & Paste Expert
They are in upside down.
guitarman376
Oct 11, 2015 01:47 AM
KingRando
Oct 1, 2015 11:16 AM
67STANGX2
Sep 24, 2015 12:29 PM
Sep 16, 2015 07:53 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
