Bama chips. (Calibration code?)
Old Oct 25, 2008 | 02:46 PM
Lethaldosage423's Avatar
Lethaldosage423
Default Bama chips. (Calibration code?)
Well, I am just about to order my C&L cold air intake and X-Cal 3 tuner from bamachips.com
im ordering it tomorrow night!!!
I am on the site, reviewing what i need and it says Calibration or strategy code. Someone said it was in the engine bay on the ECU is it?
And the tunes:
for sure, the performance 87
but which two 91 tunes should i get?
the 91 Race, 91 Torque, or the 91 Performance?
When the time comes to get my car smogged, I have to set my tune to defult. Does this mean i also have to put the stock air box back on?
And should i install the CAI first then the tunes or the tune then the cai?
Thanks alot guys, i know there are a lot of people on here with this setup so i trust you! lol
-Chris
Old Oct 25, 2008 | 02:53 PM
157dB's Avatar
157dB
Cut & Paste Expert
And the tunes:
-Chris
Its sticker on the PCM under the hood. The PCM stratagy code.
Tune back to OEM AND the OEM airbox needs to be replaced
for smog checks.
Proper Octane fuel first, CAI, install tune, then drive her to let
the adaptive learning relearn if the battery was disconnected.
Old Oct 25, 2008 | 03:12 PM
themac5150's Avatar
themac5150
The cal code was on a small sticker, 4 digits, mine was HSV3, yours may be different. If you're returning to stock for any reason, yes you will have to put the stock air box back on, DO NOT THROW/GIVE/SELL any of that stuff away. It doesn't matter which one you do first as long as you don't drive it until both the intake and tune are installed. I like to start the tune installation for the new intake while I'm removing old. The car makes the same noise when you put your key in and turn it to on, all of those gizmos firing up. Well, when the tune finishes loading, it does it again. That's how I know it's done, and I can go start the procedures to turn it off. Not really an issue with the xcal, but the Ford program tool takes 3 times as long to install a tune. I'm always swapping my intakes around.
Old Oct 25, 2008 | 03:15 PM
Lethaldosage423
Thank you so much!
im going to check it out now.
god i cant wait to get it and install it. Installing mods are the biggest part of the fun!!!
thanks again
Old Oct 25, 2008 | 04:20 PM
themac5150's Avatar
themac5150
Did you find it?
http://www.allfordmustangs.com/forum...es-cpucode.jpg
Old Oct 25, 2008 | 04:26 PM
Lethaldosage423
Yep thank you, its DUR3
What 91 tunes should i get tho?
Old Oct 25, 2008 | 04:34 PM
loaded6shooter's Avatar
loaded6shooter
def get the race tune, thats what i run all the time. havent changed it since.
only other time i used a different tune was when i used the 87 perf while i was going through that tank of gas.....race tune ever since
Old Oct 25, 2008 | 04:59 PM
themac5150's Avatar
themac5150
When I got mine, I got the 87 perf, 93 perf, 93 torq. I don't race, so I didn't think I needed a "race" tune. Everyone that has the race tune loves it. I have 93 available, so I got it. The 87 perf is good too. Much better than stock. And when 93 was unavailable on road trips, it came in real handy. It also came in handy during the recent shortages we had due to the hurricane. Strangely, 93 was nowhere to be found. So off came the FRPP CAI, on went the C&L and Bama with 87. So just think about what you'll be able to get all the time, and have a back-up tune for it. I pulled into a gas station one time, and grabbed the premium handle and pumped a full tank of what I thought was 93... just happened to glance at the little yellow sticker and... it wasn't. Luckily, I carried the xcal in a shaving kit bag in the trunk. I just flashed it for the 87 and rolled. For the X, I went with 91. I've been on the road and too many times 93 wasn't to be had, and with the X, premium is the only option. The FRPP CAI calibration is a 91+ tune.
Old Oct 25, 2008 | 05:05 PM
Lethaldosage423
Thank you Again lol
Im in So Cal so i dont have 93 available so i use 91.
Well i decided i cant wait till tomorow so i JUST PLACED MY ORDER!!!! im very excited. Im going to be looking forward to it all week.
I decided to go with the:
87 Performance
91 Race
91 Torque
Im low on gas right now so ill fill her up with 91 after work just to run a tank through
I cant wait!!
Old Oct 25, 2008 | 05:08 PM
themac5150's Avatar
themac5150
The torq was my fav, and stayed in the car. It made the car pull harder down low, great for day to day driving.
