Old 10-15-2015, 07:09 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Specifications & General Maintenance
Print Wikipost
requesting help with TSB's
Old 11-02-2008, 05:51 PM
oaussieo
oaussieo's Avatar
Default requesting help with TSB's
Hello all, I am having some trouble with the front brakes on my V6 mustang and I am not able to find any TSB's at all, well thats not true I can find them but they all want ????, no sorry this should be free
Does any one know of a location I can find a list of TSB's or can you assist me if there is one for the front braking system as I am feeling a vibration when applying the brakes
Thanks for your help on this
oaussieo is offline
Old 11-02-2008, 05:53 PM
2005Redfire6
2005Redfire6's Avatar
Warped rotor maybe?
2005Redfire6 is offline
Old 11-02-2008, 05:55 PM
jdphillips73
jdphillips73's Avatar
i dont know of any tsb's for brakes
jdphillips73 is offline
Old 11-03-2008, 12:12 PM
afixer
afixer's Avatar
here is the most recent list of TSBs for the 05
is this the one? 05-18-10 BRAKE NOISE - VEHICLES BUILT BEFORE 3/8/2005
Technical Service Bulletins
2005 MUSTANG - US (English)
08-21-7 POWER WINDOW FEATURE - BOUNCE BACK DIAGNOSTICS
08-21-6 AXLE WHINE
08-20-10 4.0L MANUAL TRANSMISSION - RPM FLUCTUATION DURING NEUTRAL COAST DOWN
08-17-3 CONVERTIBLE - REAR QUARTER GLASS - TORN/SEPARATING QUARTER GLASS DIVISION BAR
08-8-5 4.0L WITH MANUAL TRANSMISSION - 4TH GEAR RATTLE/KNOCK NOISE ON ACCELERATION - 1800-2200 RPM APPROXIMATELY 45 MPH (72 KM/H)
08-7-6 SPARK PLUG REMOVAL INSTRUCTIONS - 4.6L 3V/5.4L 3V/6.8L 3V
08-5-10 8.8 LIMITED SLIP AXLE MOAN/GROAN NOISE DURING LOW SPEED TURNING MANEUVERS
08-4-17 ERRATIC FUEL GAUGE
08-3-4 RATTLE/BUZZ/VIBRATION - TRANSMISSION CROSS-MEMBER EXHAUST MOUNT - BUILT BEFORE 12/3/2007
08-2-10 4.6L MANUAL TRANSMISSION - SEPARATOR PLATE BUZZ - BUILT BEFORE 12/13/2007
08-2-4 MANUAL TRANSMISSION SHIFTER BOOT NOISE - BUILT BEFORE 12/6/2007
07-23-1 GRUNT/CREAK/SQUEAK/CHIRP NOISE FROM THE LOWER CONTROL ARM BUSHING OVER BUMPS - BUILT BEFORE 2/28/2007
07-21-12 FUEL FILL SLOW, OR DIFFICULT TO FILL
07-20-3 CONVERTIBLE TOP - TENSION CABLE NOISE - BUILT BEFORE 12/1/2006
07-19-1 CONVERTIBLE TOP WEAR - BUILT BEFORE 10/11/2006
07-18-2 4.0L AND 4.6L COUPE - FRONT END NOISE OVER BUMPS
07-18-1 FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
07-17-8 CONVERTIBLE SYSTEM CONCERNS
07-17-6 BUZZ/RATTLE FROM DOOR PANEL WHEN OPERATING AUDIO SYSTEM - VEHICLES BUILT BEFORE 8/2/2007
07-16-7 EXTERIOR DOOR HANDLE NOT FLUSH IN THE CLOSED POSITION
07-14-6 WATER LEAK - FRONT FLOOR AREA
07-12-3 RCM FAULT REPORTING USING DTCS AND BIT-MAPPED PARAMETER IDENTIFIERS (PIDS) - SERVICE TIPS
07-5-13 DISCHARGED BATTERIES - VEHICLES IN STORAGE/LIMITED USAGE
07-5-8 BATTERY SERVICE - OPERATION OF BATTERY EYE - CHARGING SERVICE TIPS
07-4-3 LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
07-3-9 MIL ON - DTC P0456
07-1-7 MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
06-26-2 CARPET REMOVE AND REPLACE
06-26-1 MERCON ATF IS BEING REPLACED BY MERCON V AS A SERVICE FLUID FOR SOME MANUAL TRANSMISSIONS
06-25-15 ALUMINUM BODY PANELS - CORROSION - SERVICE TIP
06-21-19 HEATER CORE LEAKAGE AND ELECTROLYSIS (INFORMATION ONLY)
06-21-7 AUDIO / NAVIGATION SERVICE AND ORDERING PROCEDURES
06-19-12 DTC P0340/P0344/P0345/P0349 - 4.6L 3V AND 5.4L 3V
06-19-8 TICKING AND / OR KNOCKING NOISE / STARTUP RATTLE FROM ENGINE - 4.6L / 5.4L 3V
06-18-16 IDENTIFYING THE CORRECT REPLACEMENT HEAD GASKET FOR CERTAIN REMANUFACTURED ENGINES - SERVICE TIP
06-17-8 SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
06-15-8 KEYPAD DIAGNOSTICS - DEALER INSTALLED ACCESSORY
06-14-3 AIR CONDITIONER COMPRESSOR CLUTCH FAILURE - REVISED COMPRESSOR CLUTCH
06-9-9 HESITATION ON ACCELERATION AFTER LONG CRUISE
06-7-10 MIL ON WITH DTC P2004 THROUGH P2008, P151A, P2015, P2020 - 4.6L 3V
06-5-4 PARK BRAKE CABLE FREEZING/REAR BRAKES DRAGGING
06-4-9 A/C COMPRESSOR NOT OPERATIONAL / LOW FREON - SHAFT SEAL LEAKS
05-22-8 WDS COP KIT DIAGNOSTIC TIPS - COIL ON PLUG (COP) IGNITION SYSTEMS - ENGINE MISFIRE OR ROUGH RUNNING
05-19-10 LOOSE SEAT CUSHION COVER TRIM ON FRONT OF FRONT SEAT
05-18-7 WIRING - SOLDERING AND CRIMPING REPAIRS - SERVICE TIPS
05-15-13 FRONT SIDE MARKER LAMP RETAINING TAB BREAKING
05-15-12 FUEL FILL SLOW, OR DIFFICULT TO FILL - VEHICLES BUILT BEFORE 4/26/2005
05-15-2 GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 2/21/2005
05-14-4 WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
05-10-19 INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
05-9-14 CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
05-9-3 INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
05-8-6 EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
05-6-15 AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
05-3-1 MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
04-26-22MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
04-26-16 WELD BONDING PROCEDURE
04-24-5 REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
04-9-6 BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
________________
TSBs found:60
afixer is offline
Old 11-03-2008, 12:52 PM
iROK24/7
iROK24/7's Avatar
Does a Ford dealer have to perform the work indicated by a TSB for free? And does the car have to still be under warranty?
I'd like them to take care of TSB 08-8-5 for me.
iROK24/7 is offline
Old 11-03-2008, 03:22 PM
sccadriver
sccadriver's Avatar
tsb is not a recall. it is just a issue that is noted as being common problems. vehicle specific. so to get it for free the car has to be under warranty. i happen to know what the problem with your car. if it is only vibrating when you apply the brakes then you need to have the rotors machined. there is no recall or tsb on this. the only way to have it done for free is if the car is still under the factory warranty and under 12k miles. ex service writer at a ford dealership.
sccadriver is offline
Old 11-03-2008, 05:09 PM
afixer
afixer's Avatar
actually the TSB's are covered up to the 3 year 36,000 mile mark if you have extended war then as long as its a part that fails they will fix it but you will pay the deductible. recalls are a whole different story. i had my lo-speed fan on my radiator fail and after three times in the shop trouble shooting it . they replaced it and all i had to pay was 100 bucks. they also took care of another issue while it was in so i didn't have to pay twice
afixer is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
UrS4
09-30-2015 10:13 AM
04stangman
09-26-2015 09:33 AM
YoungStangsMan
09-05-2015 07:01 PM
Casper98GT
02-21-2005 10:07 PM
Quick Reply: requesting help with TSB's
