weird problem
Old Apr 17, 2009 | 09:04 AM
T_4500's Avatar
T_4500
Default weird problem
So my room mate wakes me up this morning and says one of my parking lights is on...so i go out side(its for some reason snowing by the way)and the front left parking light is on nothing else.I turned on and off the lights,tried the turn signals it does not blink(back does),then disconnected the battery and reconnected it...still on.any one know what would cause this?
Old Apr 17, 2009 | 09:12 AM
07 Stang's Avatar
07 Stang
Check to see if your floor is damp on the passengers side. In fact, check all carpet areas for signs of water leaks. If water is leaking on electrical contacts, it causes all kinds of weird problems. There is a TSB on it, 07-14-06.
Old Apr 17, 2009 | 09:13 AM
28HopUp's Avatar
28HopUp
MF Administrator
Any water leaks? Some S197's have had issues where water got into the ECM/junction box and caused freaky electrical issues. Take it back to the dealer if you are still under warranty.
EDIT: I see Sandy beat me by about 1 minute!
Old Apr 17, 2009 | 09:24 AM
157dB's Avatar
157dB
Cut & Paste Expert
The water leak has molded your carpet and corroded the smart junction box
that controls most electrical lighting functions and other things.
https://mustangforums.com/forum/4-0l...ater-leak.html
Attached Thumbnails weird problem-leaktsb.jpg   weird problem-man_desperation.jpg
Old Apr 17, 2009 | 09:36 AM
T_4500's Avatar
T_4500
Thanks for the help after it stops dumping snow Im taking it in.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
MasterLanMan
Sep 13, 2015 08:21 PM
