installed zex.....question
Old May 8, 2009 | 07:20 PM
Paulejr13's Avatar
Paulejr13
Banned
Default installed zex.....question
Hey. Have the zex kit installed with a wot switch and rpm window switch. I'm running a 75 shot with dual exaust and intake. My tuner was stolen and I dnt have the extra cash to buy another tuner and tune.
Will I be ok with the 75 shot with wot and rpm switches? Mainly to test and only run it for about a month or so till I get the money
Old May 8, 2009 | 09:21 PM
jimkaray's Avatar
jimkaray
It would be safer with just the 50 shot. But if you run 93 octane and one step colder plugs, like the NGK TR6's, you should be ok. I wouldn't run it up to the redline or spray it too often until you get a nitrous specific tune.
Old May 9, 2009 | 02:46 AM
Paulejr13's Avatar
Paulejr13
Banned
any more info?
Old May 11, 2009 | 11:49 AM
melo15fan15's Avatar
melo15fan15
i ran mine without a tune for a while. Took it too the track for quite a few passes and no complaints or problems. I have a window switch as well and as long as you programmed it to spray in a safe range you should be okay
Old May 11, 2009 | 04:25 PM
Paulejr13's Avatar
Paulejr13
Banned
thanks! any others?
Old May 11, 2009 | 06:32 PM
rygenstormlocke's Avatar
rygenstormlocke
Personally, I wouldn't run nitrous without a tuner and pulling a few degrees of timing.
Old May 11, 2009 | 10:15 PM
melo15fan15
I have since gotten a tune with timing pulled, however, for MILD/MODERATE usage (i suggest track only) you will be safe for a bit. Like i said before, i have done it without a tune and it worked flawlessly. However, the tune did boost my 1/4 ET
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
