Problem with starter... I think
Old Jun 30, 2009 | 11:48 AM
krussdog46's Avatar
krussdog46
Default Problem with starter... I think
This morning I went out to fire up my 07' v6 and nothing happened. My sister used the car last night and I think she left the door open and killed the battery. I put a charger on it and waited a while. When I try to start it now it makes a clicking noise but doesn't turn over. The clicking noise clicks about every second. Not like the rapid clicking of a dead battery, it clicks about once per second but simply won't turn over. I have also tried starting it with a jump charge and have gotten the same result. I have checked all of the fuses and am completely lost. Has anyone else had this issue or have any idea how to fix it? Any help is appreciated.
Old Jun 30, 2009 | 12:07 PM
GrayPony's Avatar
GrayPony
Sounds like you need to replace the battery.
Old Jun 30, 2009 | 02:15 PM
schapman's Avatar
schapman
I had the same problem and my car wouldnt start with the battery charger. new battery and it started right up.
Old Jun 30, 2009 | 03:22 PM
28HopUp's Avatar
28HopUp
MF Administrator
My money is on the Shaker 500 radio draining your battery down. You SHOULD be able to jump start it with good cables from another car that's running. Make sure you have good connections.
Old Jun 30, 2009 | 05:04 PM
157dB's Avatar
157dB
Cut & Paste Expert
The door light will go out after 15 minutes regardless of the door being open.
You have bigger troubles than just leaving the door open.
Go appologize to your sister for giving her the busisness for
leaving the door open and killing your battery which she didnt do.
Old Jun 30, 2009 | 08:56 PM
krussdog46's Avatar
krussdog46
I took the battery out and had it load tested at an auto parts store. The battery was bad and when I put a new battery in the car started right up. I noticed in the previous couple days that the car hadn't been starting as easily as usual. I have a feeling that the battery hadn't been holding a charge and just finally kicked the bucket. Regardless, the problem is fixed for now and I assume for good unless there is something causing the battery to discharge.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
