Intake mod
Old 07-07-2009, 11:04 PM
astivers1503
astivers1503's Avatar
Default Intake mod
I need to attach the PCV tube to the whole I drilled in the intake pipe, the PCV tube is not flexible. So I want to know if I can replace it with any other tube with the same resistance qualities that I can bend to fit where I need it, or do they make one?
astivers1503 is offline
Old 07-08-2009, 05:57 AM
GrayPony
GrayPony's Avatar
The intake pipe didn't come with a hose and fitting?
GrayPony is offline
Old 07-08-2009, 11:03 AM
157dB
Cut & Paste Expert
157dB's Avatar
Drilled a hole for what?
To lean out the fuel mixture
out of the parameter tables?
PVC on a stang engine?
I will have no part of that......
Prediction:
His next post will be about the light
on the dash and the codes its throwing...
157dB is offline
Old 07-08-2009, 11:23 AM
BigGameHunter589
BigGameHunter589's Avatar
what exactly are you doing to your intake?
BigGameHunter589 is offline
Old 07-08-2009, 12:57 PM
tx_zstang
tx_zstang's Avatar
You can use 5/8" flexible hose, preferably fuel hose.
yeah, wtf are you doing???
tx_zstang is offline
Old 07-08-2009, 05:30 PM
Sancho805
Sancho805's Avatar
please tell us WTF you're doing to your intake!!!???
Sancho805 is offline
Old 07-09-2009, 04:47 PM
ABQstang89
ABQstang89's Avatar
um yeah what are you doing? nitrous or something?
ABQstang89 is offline
Old 07-09-2009, 05:57 PM
hataap
hataap's Avatar
PVC tube? Drilled hole? wtf...
hataap is offline
Old 07-10-2009, 08:11 AM
157dB
Cut & Paste Expert
157dB's Avatar
Hooked,
Lined and sinkered.....
157dB is offline
Old 07-11-2009, 07:34 AM
rls82959
rls82959's Avatar
Are you making a CAI? Your PCM ain't gonna like that.
rls82959 is offline
Quick Reply: Intake mod
