engine swap
Old Aug 11, 2009 | 04:46 PM
ABQstang89's Avatar
ABQstang89
Everyone always says just trade in for a GT. They are right if your set on going with a 4.6. If your gonna do an engine swap why not look at the 5.4 to make it worth all the cash you will drop on it.
Old Aug 11, 2009 | 05:18 PM
pascal's Avatar
pascal
S197 Section Modder-ator
I agree.
Going through the trouble of it all...
Reward yourself with something more unique than the 4.6 GT mill.
If I was to do this, I'd get a combo that gets me 500rwhp at least...
Old Aug 12, 2009 | 10:34 AM
07lane40's Avatar
07lane40
Originally Posted by 157db
Yes, but why when Ford sells them that way.
You would have a screwed up V6 in the end.
You will need to beef up the tranny if it is a manual
and the 7.5" rear end has to go. Then the front
brakes need to be swapped to GT rotors to stop this
Frankenstein V6 thats now a V8.
Sell the V6 and buy a GT unless you are made of money....
first of all, the GT rotors will make a small difference. SMALL. they use the same calipers, clamping force will be the same, just the rotational force of the brakes will be different, but only slightly 12.8" vs 11.5. you can get GT500 takeoffs for cheap that will make an actual difference.
2nd of all the 7.5" doesnt have to go, it just needs to be dealt with. Getting mine built with an Auburn posi, new 4.10 gears will run 850. stonger and cheaper than a 8.8" rear with the 4.10's. not to mention lighter.
the only part youre significantly right about in this is that the T5 is weak. DUH
yeah all in all it would run about 4-8k depending on where you get your engine, what kind, tranny and rear, etc, but its much more interesting, and can be potentially cheaper depending on what kind of shape your stang is in. my modified 6 would get about 12k at the dealership. that leaves me with around 16-20k to pay (assuming its paid off). not worth it. you forget that these cars aren't getting younger. and they're one of the most interchangeable and easily modified cars on the planet.
Old Aug 12, 2009 | 12:36 PM
THEBLACKSTANG's Avatar
THEBLACKSTANG
Yes you can... but you shouldn't
Old Aug 12, 2009 | 01:29 PM
wynsboy's Avatar
wynsboy
i like the idea of putting the 5.4L 3v from the f150 in. from what i have read, it has the same head as the 4.6 so u can use the same wiring harness and electronics. then u just have to dyno. that would be a sweat project. the other idea ive had is getting a 6.0L diesel but that is just crazy talk.
Old Aug 12, 2009 | 02:16 PM
ABQstang89's Avatar
ABQstang89
There are a few 6's that have done the 5.4 swap. If I remember correctly the f 150 can come with the 4v as well but its an upgraded feature. Don't know if you could find one though.
Old Aug 12, 2009 | 02:43 PM
killdar's Avatar
killdar
Myabe 10 years down the road when my engines pretty beat I'll swap it out
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
97SN95GT
Sep 13, 2015 09:45 PM
mdj89
Sep 6, 2015 11:08 PM
zachary1988
Sep 4, 2015 03:04 PM
