small issue
Old Sep 16, 2009 | 09:46 PM
rootn1's Avatar
rootn1
Unhappy small issue
this weekend i had my car up on the lift to change my clutch. after i finished i hooked the battery back up and took her off the lift. However my A/C no longer works. i have gone through every single test in my ford workshop manual with no results. The only thing i can tell you is when i turn on the A/C the light comes on but the A/C clutch dose not engage. I have checked and double checked all the fuses and relays. sooo any ideas?
Old Sep 16, 2009 | 10:09 PM
GrayPony's Avatar
GrayPony
Refrigerant is low and the pressure switch is tripping power to the clutch. Evacuate and re-charge the system
Old Sep 16, 2009 | 10:11 PM
rootn1's Avatar
rootn1
i thought that as well, i discharged and recharged the system with no results
Old Sep 16, 2009 | 11:16 PM
GrayPony's Avatar
GrayPony
Questions, questions...
Fuse F14 in the smart junction box good? There are 2 switches that control power... the ac clutch cycling press switch (fed by S14) the pressure transducer (works with the pcm). Relay fuse F49 good? I assume you checked the clutch relay. Did you check power across the relay? Did you jump power to the clutch to confirm the field coil is working and the clutch engages?
If the clutch won't cycle how could you recharge the system? Without the compressor running there will not be enough difference in pressure between the high and low side to recharge the system properly.
Steps:
First an foremost... check that you do not have the water logged SJB problem
Check ac related fuses
Check for power to the relay (term 30 is fed by fuse F49) the PCM powers the coil of the relay. (The pressure switches send info to the PCM. The climate control module sends signals to the SJB)
Jump power to the clutch to check the field coil -- if this engages the clutch, check for power across the relay when the switch is on --- if none, it could be low system pressure faulty component in the system.
Old Sep 17, 2009 | 08:03 AM
Nuke's Avatar
Nuke
Here's a long shot: Unplug the harness to the compressor, clean the contacts on both the male and female and reconnect. I had the same issue on my son's car and that did the trick.
Old Sep 17, 2009 | 09:53 AM
rootn1's Avatar
rootn1
well nuke you were right that did the trick hummm so simple i overlooked it thanks guys for your help
Old Sep 17, 2009 | 10:48 AM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by GrayPony
Steps:
The SJB does not control the Climate Control Module.....
The Climate Control is an independent system......
Old Sep 17, 2009 | 01:59 PM
Nuke's Avatar
Nuke
Wow, I was RIGHT. I need 8 hours of sleep...
Old Sep 17, 2009 | 08:05 PM
GrayPony's Avatar
GrayPony
I never said the SJB controls the climate control module... info is passed thru the SJB by the climate control module. He was having clutch issues and the clutch request is passed thru the SJB.
Old Sep 17, 2009 | 08:17 PM
rootn1's Avatar
rootn1
GrayPony u make valid point here ill have to say. i have a ford factory manual, but i like ur diagrams a lot better where u get them?
