What to do next
Old Oct 31, 2009 | 07:50 PM
4.0 $tang's Avatar
4.0 $tang
Default What to do next
i am out of ideas to make more power out of the stang...Got the Aluminum DS and Flywheel on the way.....they are not even here yet and i am thinking what next.....NO Juice or X...any suggestions, i want to get all the parts in for spring as i am covering the car next week for the fall and winter...
thanks J
Old Nov 2, 2009 | 08:01 AM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Without some sort of power adder, you won't get much more out of your car.
You can try heads/cams but at the cost you might as well go with an FI setup.
Old Nov 2, 2009 | 08:18 AM
legendlime05's Avatar
legendlime05
if youre modding just to mod throttle body
Old Nov 2, 2009 | 10:14 AM
4.0 $tang's Avatar
4.0 $tang
i am modding to drop my e.t. and up my mph in the 1/4 mile...i am stuck at 14.2-14.4 depending on weather conditions and my mph is between 94-95....i wanna be a 13 second v6
Old Nov 2, 2009 | 10:19 AM
jtstakelin's Avatar
jtstakelin
Are you using a DR or just regular street tires?
Old Nov 2, 2009 | 02:28 PM
Avalanch3's Avatar
Avalanch3
Get some LCA's with relocation brackets to lower the 60' ft time.
Old Nov 2, 2009 | 02:30 PM
4.0 $tang's Avatar
4.0 $tang
regular street tires, i am afraid of busting my rear with DR, only using a 7.5 rear end
Old Nov 2, 2009 | 04:44 PM
rygenstormlocke's Avatar
rygenstormlocke
Put some inexpensive Jeg's drag lites on it. Front and rear for additional savings. Look at a rear seat delete and look into taking the 48lb passenger seat out.
EDIT. Tlok is fine at your power levels. I was cutting low 12's on a tloc with 3.73's. I did eventually put a lpw girdle cover on it though
Old Nov 2, 2009 | 09:10 PM
beaustang's Avatar
beaustang
What Rygen said ^^^^^^^
Old Nov 8, 2009 | 05:00 PM
4.0 $tang's Avatar
4.0 $tang
thanks for the ideas...keep em comin
