This is embarrassing..
I bought a Roush retro style shifter **** and for the life of me do not understand how it goes on. It only has 3 parts to it, I feel like I'm senseless and missing something obvious. I've installed driveshafts, cold air instakes, etc, but I can't figure out a shifter ****
Help is appreciated before I lose my mind
Don't worry about it man, it can be tricky to get perfect and its stupid of Roush not to send instructions. I used to have this **** and finally found this process got it straight and tightened perfectly:
1. Take out stock **** and place plastic Roush piece in the boot, with the cylinder pointing up.
2. Push the plastic down and screw the bolt on a little bit, maybe a little more than a 1/4"
3. Screw the ball on top of the shifter threading that is now above the **** and tighten the ball and bolt together. When they're perfectly tight the ball should end up straight.
4. You might have to play with Step 2 to get it to end perfectly, just play around a bit, you're pretty handy lol
Thanks, I finally figured it out after looking at a picture of one in-car. I too thought it was odd I didn't at least get a note mentioning how to line everything up.
Ah well, another successful mini-mod.
https://mustangforums.com/forum/2010...fter-****.html
google works great lol wish the search on here worked as good.
Hah yes that's actually the picture I looked at as a reference.
And I don't think I will ever want to buy an automatic unless something restrains me, like a bad left leg or right arm. Nothing against them, they win drags more often then not, but with a manual you feel like you're actually driving the car, not the other way around.
