engine clatter
Old Feb 14, 2010 | 07:57 AM
mpatilla's Avatar
mpatilla
Default engine clatter
I have a stock V6. It makes some irregular clattering noises after the engine warms up and is sitting at idle. I think it probably makes the noise all of the time, but you can only hear it when the engine is at low rpm. It has always made this noise and I have just accepted it as normal. However, I have just been wondering lately if this is the case. Do your cars make this noise also? Is it normal, or is there something wrong with a pulley or belt tensioner?
Thanks!
Old Feb 14, 2010 | 10:43 AM
antipeterleague's Avatar
antipeterleague
is it like a constant ticking sound? cause my car does that when still cold and idling.
Old Feb 14, 2010 | 11:39 AM
07 Stang's Avatar
07 Stang
Our 4.0 engine is very noisey, Motor Trend mag. loves to pick on it.
Wished we had the 3.7 like the Lincoln and new 2011 V6. The GT boys are worried about the new 5.0, they should be concerned about the new 2011 V6 too! I'm sure in 2011 nothing will change as far as the V6 bashing. We are all part ot the Mustang family and our older brothers do like to pick on our lower hp......be it 4.6 Vs 4.0 or in 2011, 5.0 Vs 3.7.
Old Feb 14, 2010 | 11:42 AM
mpatilla's Avatar
mpatilla
Yes, sort of. It's not really a steady rhythm. It's kind of irregular. Does your not do it after the engine is at operating temperature?
Old Feb 14, 2010 | 12:34 PM
mpatilla's Avatar
mpatilla
Yeah, I have a good friend with one of the newer T-birds. Has the 3.9 Lincoln and it is really nice. Thanks for the info, that makes me feel better!
Old Feb 14, 2010 | 06:09 PM
chronos's Avatar
chronos
Try a thicker grade of oil, see if that makes any difference. Otherwise then you may have to hunt around for that ticking noise. Use a mechanics stethoscope.
Old Feb 14, 2010 | 07:00 PM
Nuke's Avatar
Nuke
There's a TSB for noisey injectors (clickety-clack) applicable to the GT's but I can't recall if it also applies to the 4.0
Old Feb 14, 2010 | 08:50 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
sure it's not the pistons slapping a bit? I thought these hyp's rattled until they expanded to the cylinder.
Old Feb 14, 2010 | 11:41 PM
mpatilla's Avatar
mpatilla
I don't think so. It seems to be more external. It also makes the noise even after a long drive.
Old Feb 14, 2010 | 11:43 PM
mpatilla's Avatar
mpatilla
I'll check that out. Would that noise be a rhythmic one, like a clock or a metronome? Or would it be more erratic?
