Installing Roush fog light wiring harness
Hey guys,
I am going to be doing this install tomorrow after school and I have looked over and over again for a decent tutorial/write up on how to wire the fog lights to a non pony package mustang. I have seen the write up around somewhere but I didnt ever save it. I have the harness currently, any help at all would be great.
Thanks in advance
Nick
Thanks in advance
Nick
Don't know about the 'kit', but for my '05, it took a couple different things to get the fogs to work. How does the kit connect to the black fuse box under the hood? Ideally it would have the connector pins for the black box connectors and you push them in place (assuming you know how to take out and remove the green side connector hold-in pieces and put them back on). Huh? yeah, sorry.
Then there has to be the trigger to turn on the lamps. I acquired a GT stock light switch, which had the fog lamp option in it. Then ran 1 wire to the inside to the switch to activate the relay to turn on the lamps.
The V6's come with only part of the system wired up; you have to complete the setup to make it work. Another one of those writeups I need to do, lol!
If you can do wiring runs, and splice wiring were needed, it's not complicated.
Diode Dynamics
28
May 26, 2022 12:02 PM
inyadreems
Aug 21, 2015 09:10 AM
