Squealing Brakes
Old May 10, 2010 | 01:16 PM
BWfVA's Avatar
BWfVA
Default Squealing Brakes
Ok I installed some Werner aftermarket brakes about a 1 1/2 years ago, might I say they were the worst brakes I have ever had I will never recomend them to anyone. Anyway about six months ago they started squealing like crazy not every time I hit the brakes but most of the time. I checked them a few weeks back and they are still good, the only thing obvious that I have seen is that the pads appear to be so hard they are eating into the rotor. Is there anything I can do to stop this squealing cause its driving me frickin nuts
Old May 10, 2010 | 01:35 PM
crazyassracer's Avatar
crazyassracer
Where did you get these pads from? What material are they made of?
Old May 10, 2010 | 04:09 PM
BWfVA's Avatar
BWfVA
Autozone and I really couldnt tell you. I hate to spend more cash on new pads but they are driving me nutin futs if I cant fix them cheap I going to replace them this summer
Old May 10, 2010 | 04:20 PM
Whitehorse10's Avatar
Whitehorse10
I would guess that it is probably the material that the pads are constructed out of that is causing the squeal. You won't be able to fix it short of any means other than replacing the pads most likely. You certainly don't want to spray any kind of lubricant on your rotors to stop it. If the pads are eating into your rotors, that is certainly bad. I would be getting them off of there as fast as I could if it was my car. Thanks for the heads up on them, I'll be sure not to put them on mine.
Old May 10, 2010 | 04:25 PM
legendlime05's Avatar
legendlime05
file this under you get what u pay for. brake pads arent anything to cheap out on
Old May 10, 2010 | 07:18 PM
kc5mhb's Avatar
kc5mhb
I seem to remember reading somewhere about putting some anti-squeal adhesive on the backs of the pads to stop the noise.
Old May 10, 2010 | 07:20 PM
Sancho805's Avatar
Sancho805
spray some WD40...
jk, buy new pads.
Old May 11, 2010 | 10:02 AM
kevinmalec's Avatar
kevinmalec
When installing break pads, the lubricant is required on the back of the pads, where the rotors touch. If the lubricant was applied properly and the breaks still squeak, you may just want to replace them out with different pads or try and ignore the sqeaking noise.
Old May 11, 2010 | 01:16 PM
rls82959's Avatar
rls82959
I think it's called Disk Quiet (red stuff).
I put it on my stock pads. It works.
Old May 11, 2010 | 02:16 PM
crazyassracer
+1
I use permatex disc brake quiet.
It's a spray on adhesive for the back of the pad.
It sticks the pad to the caliper piston, reducing vibration and eliminating noise.
Lubricating the back of the pad will do nothing.
Here's a pic I found off the net. It's not the spray-on, but similar. Hope it helps
http://members.rennlist.com/v1uhoh/permatex.jpg
