Stroker kit?
Hey guys I've been looking into maybe a stroker kit but have no idea how it works, exactly what does it replace and how does it increase the motor from 4.0 to 4.3L? Also is it worth it? The only kit I can manage to find is this one:
http://www.moranav6racing.com/catego...?CategoryID=32
I have heard that the cylinder walls are pretty thin so there isn't much boring to be done.
Would it sound better? yes. Would it gain performance you can feel? yes. however, 30 lbs/hp for ~$4k? I wouldn't. Buy a vortech supercharger for $3400 (or less if its a good deal) and get your self 85hp at the crank. That will bring you up to NewEdge HP levels. Add a HI PO pulley and an intercooler and you can go even higher. 330 if I remember correctly.
Just a thought
Just a thought
Would it sound better? yes. Would it gain performance you can feel? yes. however, 30 lbs/hp for ~$4k? I wouldn't. Buy a vortech supercharger for $3400 (or less if its a good deal) and get your self $85hp at the crank. That will bring you up to NewEdge HP levels. Add a HI PO pulley and an intercooler and you can go even higher. 330 if I remember correctly.
Just a thought
Just a thought
If you want a built motor for FI go here:
http://www.supersixmotorsports.com/
http://www.supersixmotorsports.com/p...1HeadsCams.pdf
http://www.supersixmotorsports.com/p...dInternals.pdf
http://www.supersixmotorsports.com/p...Cdynotest1.pdf
If I had the money I would love to have their heads and cams. Just going stage 2 heads gives you a great tq curve. starts peaking earlier and holds it through the whole range. No it's not a massive gain like a SC but for NA (until you FI) its a nasty low end tq monster for an NA v6.
