just installed cai, having a problem
Old Mar 25, 2011 | 02:24 PM
aerbourne's Avatar
aerbourne
Default just installed cai, having a problem
came home from college for the day to install my new ford racing cold air intake. it was very easy and straightforward, but when i turned my car on, it makes a throbbing sort of noise in park and the rpm needle keeps bobbing up and down slightly.
i got a tuner too, but havent installed the tune yet.
any idea why this is happening?
Old Mar 25, 2011 | 02:30 PM
aerbourne's Avatar
aerbourne
eff, just realized it says it needs the tune lol, im going to do that real quick and i will be right back
Old Mar 25, 2011 | 02:41 PM
Derf00's Avatar
Derf00
Gentleman's Relish
yeah...there is warning that came in the box for your CAI that states the CAI must be used with an engine tune and in failing to retune the engine could result in engine damage (or something like that)...
Old Mar 25, 2011 | 03:04 PM
157dB's Avatar
157dB
Cut & Paste Expert
Um, disconnect the battery for 20 mins to reset the 'adaptive learning'.
While you arer waiting, read the owners manual about battery disconnection
and adaptive learning relearning procedure.
Old Mar 25, 2011 | 03:11 PM
alkemist's Avatar
alkemist
Hopefully you picked up a custom tune also..
Old Mar 25, 2011 | 03:14 PM
Derf00's Avatar
Derf00
Gentleman's Relish
That would help after he has the proper tune loaded
Old Mar 25, 2011 | 03:30 PM
aerbourne's Avatar
aerbourne
worked perfectly fine after i installed the tune...sorry for clouding up the forum with trash lol
and i got a custom tune. didnt notice much of a difference other than the shifts being alot crisper...but i just feel manly having it in my car haha
Old Mar 25, 2011 | 03:36 PM
turbo 2.8's Avatar
turbo 2.8
hmmm I thought loading a tune reset the adaptive learning , no?
I don't want to misquote anyone , but i thought that's what Justin told me a Vmp
Old Mar 25, 2011 | 04:48 PM
Nuke's Avatar
Nuke
I don't believe loading the tune resets the Adaptive Learning.
Had you taken the car out stock for some WOT runs just before the install and then done the same AFTER the install, you'd have noticed a difference. Driving granny style, you might not notice if you were SC'd, let alone a custom tune.
Old Mar 25, 2011 | 08:10 PM
turbo 2.8's Avatar
turbo 2.8
just looked at e-mail i was sent , here is part of it.
"To gather proper datalogs, follow these instructions. Use the attached config file and the latest version of SCT Live Link from http://sctflash.com/tsaddons.php?type=DL. Warm the vehicle up, then reflash the PCM to reset the learned values. "
