tire help
That depends because "best" is a relative term. What do you want to do with the car? Something that is "best" for the dragstrip won't be good on the street. Something that is great on the street won't be as good on the road course.
You must have the 17" bullitts on your car then if you are running a 235/55 x 17 tire - so you don't have the stock 16" wheel apparently. With that, the Nitto's that you posted would fit, although they recommend a 9" wheel and the stock bullit is 8" (wheel width so the dimension on the bullitt is 17x8).
'Race tires' though will not give you the wear on the street as a high performance passenger tire. The Nitto you posted though is not the Nitto 555R which is the drag radial version of that tire, and is designed for street performance so more appropriate to your intended use.
Others may have ideas on different street performance tires for you to consider. I still run on the Pirelli P-zero's on my car and have been happy with those. For the track I have a completely different set up with a bias ply rear "cheater slick" and narrow fronts.
