Brake pad replacement - special tool
Old May 6, 2011 | 09:49 AM
vbrecken's Avatar
vbrecken
Default Brake pad replacement - special tool
Installation of the rear brake pads calls for the use of a special tool (according to the service manual), called a Rear Brake Caliper Piston Adjuster. Is this tool really required? Is there something else that can be substituted or can I borrow one from AutoZone, etc...?
Thanks.
Old May 6, 2011 | 11:36 AM
turbo 2.8's Avatar
turbo 2.8
yes you need the tool , you can use one at Auto zone . they will bill your credit card for the price of the tool and reimburse you when you bring it back . I did mine about 2 months ago , piece of cake . I also bought so white lithium grease and lubed the pins and inside the boots
Old May 6, 2011 | 12:02 PM
Alec's Avatar
Alec
Yes it definitely helps. I bought mine from Harbor Freight for under $20 if I recall correctly.
Old May 6, 2011 | 12:20 PM
vnmous97's Avatar
vnmous97
hey guys i have 3 complete sets of GT take off brakes... i just did the swap on my gf 08 V6
premium stops great, if you are interested give me a call $260.00 shipped complete
281 999 9969 ask for J.R.
Old May 6, 2011 | 01:40 PM
kevinmalec's Avatar
kevinmalec
I also purchased my caliper brake kit from Harbor Freight for $19.99. 1st time you use it, it pays for itself! Plus you can help other friends/family members or charge them, which ever you prefer. =-)
Old May 7, 2011 | 06:09 AM
2005Redfire6's Avatar
2005Redfire6
I've never used one, I just use needle nose pliers. There is a groove on each side of the brake piston. Just grab both of those with the pliers and push down and turn, works fine .
Old May 9, 2011 | 01:46 AM
Funster_2011V6's Avatar
Funster_2011V6
I use needlenose pliers as well. Just dont slip and tear the seal.
Old May 9, 2011 | 07:51 AM
JCON's Avatar
JCON
When I did my brakes, all I used was a vice, and air compressor and a basic set of hand tools. Never used a caliper adjuster.
Old May 9, 2011 | 09:49 AM
2005Redfire6
You can't really use a vice on the rears.... They have to be turned in like a screw!
Old May 9, 2011 | 10:25 PM
JCON's Avatar
JCON
Good thing I only replaced the fronts :X
