manual gearbox oil changing
yo peeps.
me 2007 4.0 v6 has only gone 12k miles..
should i change the gearbox oil yet?
if so where is the top up plug?
i found the drain plug easy.
what's the best oil i can use for it?
cheers ole phucker
cheers ole phucker
http://iihs.net/fsm/?dir=279&viewfil...%20Filling.pdf
Yes, there is a top fill hole.
12K miles does not warrant a gear oil change.
BTW its ATF in there, not 'gear oil'.
I changed mine to AMSOIL ATF and have not looked back since.
It shifts oh so much smoother...
Unfortunately, AMSOIL is not available thru eBay, only
licensed AMSOIL dealers.
EDIT: I guess I am wrong or this seller will be getting into trouble...
http://www.ebay.com/itm/AMSOIL-Synth...c8697d&vxp=mtr
http://www.amsoil.com/shop/by-produc...mission-fluid/
This is what I am running in the rear differental.
http://www.amsoil.com/shop/by-produc...-gear-75w-140/
I am thinking about changing my trans fluid soon also, my 07 has 66,000 on it. I have always use Motorcraft MERCON V in my other car and it has been great. So, i'm just wondering do you really think the AMSOIL is a better choice than motorcraft? I have never used anything AMSOIL so i have no experience with it
So, are you saying that MotorCraft lubes are not manufactured in the USA? I have never really search on it but i assumed that they were
i used synchromesh in mine and liked it. def quieted it down some and cut down on the grinding from 2nd to 3rd when cold a bit. im going to try the amsoil next time but i ahve no complaints about the synchromesh
