Is this real?? Driveshaft Fail
Old Feb 11, 2012 | 12:31 PM
157dB's Avatar
157dB
Cut & Paste Expert
The first 05 V6 S197s had PRESSED IN U-Joint caps.
The centrifugal forces would cause the caps to walk out
of the end yolks on the driveshaft at speeds over 115 MPH.
The later models of the S197 V6s have retaining clips holding
the U-Joint caps into the driveshaft yokes.
Go figure.
Not sure about the GTs two place driveshaft...
Old Feb 11, 2012 | 12:51 PM
zacfrost's Avatar
zacfrost
ive had my 96 v6 stang up to 110 plenty of times and had no major issues with the drive shaft, tho i had a radiator hose burst ,smelt anti freeze for bout 3 weeks after that.
Old Mar 23, 2012 | 10:00 PM
CaptainRon's Avatar
CaptainRon
I think theres a lot of misinformation out there on the web and you tube regarding this "rumor", and it is a rumor, nothing more.
After working with a friend that rebuilds driveshafts for 35 years, Ive never heard of a shaft failing at speeds, I've heard of U-joints failing, and thats usually at a hard launch, but driveshafts? nope, never.
Old Mar 24, 2012 | 10:18 AM
157dB's Avatar
157dB
Cut & Paste Expert
GOOGLE IS GOD
http://coloradofans.com/forums/62-vi...haft-fail.html
Old Mar 24, 2012 | 04:47 PM
CaptainRon's Avatar
CaptainRon
Originally Posted by 157dB
That's not a driveshaft from a V6 Ford Mustang.....
The only time I've experienced a "driveshaft" failure it was really the U-joint, and after quite a few hard launches, never ever have i heard or experienced a shaft blowing apart from high speed driving.... I think this rumor started back when Shaftmasters experienced some failures on their 1st generation shafts.
Old Mar 24, 2012 | 10:48 PM
2005Redfire6's Avatar
2005Redfire6
The 2005's and some 2006s had a similar issue where retaining clips were not used on the drive shaft and they could back out at speeds around the limiter.
Old Mar 25, 2012 | 11:26 AM
CaptainRon's Avatar
CaptainRon
I never heard of those ever backing out at highway speeds or above. Now at the drag strips yeah, U-joint failure is commonplace. Thats why some guys replace their shafts with aftermarket pieces and then even some of those fail, sometimes on the firt run....
Old Mar 30, 2012 | 11:29 AM
157dB's Avatar
157dB
Cut & Paste Expert
Ford has heard of it happening.
Because Capt Ronny has not seen or
heard of it, it just has never happened, ever.
LOL JK firt
Old Mar 30, 2012 | 03:47 PM
tigercrazy718's Avatar
tigercrazy718
dont we have a member whos DS failed on the dyno? he has the yellow mustang with the xcharger and black stripes. cant remember the name tho
Old Mar 30, 2012 | 08:27 PM
JimC's Avatar
Super Moderator
That would be Afixer, and yes his driveshaft came apart on the dyno with his 2005.
