Starter Computer controlled?
Old Dec 19, 2012 | 01:32 PM
vegas_'s Avatar
vegas_
Question Starter Computer controlled?
It seems to me that the starter in my Mustang (2013 V6 Auto) is controlled by a computer. ( Like in cars with pushbutton start.)
If I just flick the key to the start position for a fraction of a second. (Like might happen if it slips out of your hand while trying to start) The car will start fine.
In older cars, if my finger slipped off the key, the starter would just run for that fraction of a second and probably not start the car.
But in my Mustang, the starter seems to crank the engine until it starts, even if I've released the key. Similarly, if I hold the key in the start position for a long time, the starter will just crank the engine until the it starts then disengage even if I'm still holding the key in the start position.
I'm assuming that when you twist the key to the start position this simply issues a command to a computer than then actually activates the starter. I'm not sure if it cranks the engine for a fixed length of time, or it's programmed to crank until the computer decides that the car has started.
Anyone else notice this?
Old Dec 19, 2012 | 01:41 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Probably not computer controlled but controlled by a delay relay or timer switch. In other words, once the relay or timer switch is enganged it is set to allow current to pass through it for a set amount of time before cutting power. This avoids the whole, crank for a split second and not start.
It's like what many new Euro cars are doing (and some domestics now), hit the turn signal switch for a split second and the turn signals for that side continue to flash for a few times.
Old Dec 19, 2012 | 04:13 PM
157dB's Avatar
157dB
Cut & Paste Expert
tHE pcm CONTROLS THE STARTING...
fricken caps lock...
key switch to pcm to starter relay to starter...
pcm no allow the starter when engine is running...
I have my starter wired on all the time and use
the clutch switch to start her...
Insert key to run and depress clutch and she starts right up...
Old Dec 20, 2012 | 09:27 AM
vegas_'s Avatar
vegas_
I'm pretty sure all this kind stuff is controlled by the computer, it's essentially free to add these types of features. Though you would need a dedicated high current output to drive the solenoid for the starter, assuming they still use solenoids.
Originally Posted by 157dB
pcm not allow the starter when engine is running...
Yeah that's probably a warranty cost item, too many idiots starting their cars while it's running, thus damaging the starter or flywheel.
It would be interesting to hear from someone in a cold climate, to see if it cranks longer in cold weather.
Old Dec 22, 2012 | 09:53 AM
157dB's Avatar
157dB
Cut & Paste Expert
The Challenger starts with a flip of the key.
Just blip it and the pcm takes over.
It cranks the engine until it starts.
This could be bad for no-starting conditions...
Old Dec 26, 2012 | 10:27 PM
2011V6Conv's Avatar
2011V6Conv
Yes, it's the same on my '11.
mrtrodonet
Sep 19, 2020 03:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
ChampInSD
Oct 2, 2015 04:55 AM
logan409
Sep 26, 2015 07:43 PM
