V6 Electronic Speed Limiter
Old 06-27-2013, 10:53 PM
thunderlevin
thunderlevin's Avatar
Default V6 Electronic Speed Limiter
Can anyone tell me if one of the inexpensive Bluetooth OBD dongles along with the "Torque" Android app, can be used to disable the 115mph electronic speed limiter in my 2008 V6 Mustang?
BAFX Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive BAFX Products (TM) - PIC18F2480 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible : Amazon.com : Automotive
thunderlevin is offline
Old 06-28-2013, 06:42 AM
Moderator
JimC's Avatar
That just lets you scan for diagnostic information, it doesn't do any programming. You need to get a tune.
JimC is offline
Old 06-28-2013, 11:58 AM
thunderlevin
Well then is there any software/hardware package that will turn a laptop into a tuner instead of having to buy a dedicated tuner that will only work on one car? A tuner is just a computer (and not a very powerful one) with some dedicated software and an OBD connector. There must be some way to do this with a laptop (or tablet) and skip buying redundant hardware, no?
Old 06-28-2013, 12:20 PM
Rudolph Hucker
Rudolph Hucker's Avatar
you want to go over 115 mph in a mustang vert?
you must be crazy dude..
i find it hard going over those speeds in a coupe v8..death wish springs to mind
Rudolph Hucker is offline
Old 06-28-2013, 12:31 PM
thunderlevin
The V6 isn't even breathing hard at 115. That's what's so frustrating. The limiter kicks in right in the middle of the power band.
Old 06-28-2013, 12:35 PM
Rudolph Hucker
what about handling and road holding?
you do know the drive shafts explode over 120 mph on the v6 dont you?
Old 06-28-2013, 01:02 PM
thunderlevin
Can anyone answer my question about using a computer rather than a dedicated tuner?
Old 06-28-2013, 01:27 PM
Nuke
Nuke's Avatar
Sorry, I can't answer your question but I think you're playing with fire, despite that a number of folks claim they can reach over 120 MPH on the stock tune in their 4.0. The 4.0's drive shaft is know to tear apart at speeds in excess of 125 MPH. And personally, I don't think ANY stock 4.0 can push much beyond 125 w/o some... "help". That's a lot of wind resistance to cut with a meager 4.0.
Nuke is offline
Old 06-28-2013, 01:44 PM
aaquib1992
aaquib1992's Avatar
The 4.0L engine itself may not be too strained (which isn't particularly correct either mind you) but the drivetrain and suspension are absolutely at their limits when you near speeds in excess of 115+ MPH.
At those speeds that two piece shaft will back out of its U-Joints and start oscillating so fast that you won't know what hit you when it finally does snap. Or just as worse, your **** poor stock OEM tires (probably the cheapo ones that came with base 4.0s) rated for less than 120MPH fail. Either way, you are causing a death wish to come true due to blissful ignorance.
As far as answering your "question", I do not know of any programs that will unlock your PCM and allow you to make changes on the fly through your computer (do you have a USB to OBDII connector?). As far as I know, most garage tuners still use their SCT tuners to upload their files into their vehicles.
I don't even want to ask if you have a roll bar for your convertible when you are doing these speeds...
aaquib1992 is offline
Old 06-28-2013, 01:46 PM
Rudolph Hucker
plus a verts chassis is dire compared to a coupe..
leave well alone dude if i was you.
as i said even a gt feels scary above those speeds...
Quick Reply: V6 Electronic Speed Limiter
