I think I found the problem, or a symptom of the problem.
Connections to the motor are melted and corroded (Pictures attached)
Obviously I need a new motor. But what do I do about the connector? Would I have to replace the whole cable? Or can I just buy a new connector and solder it to existing wires?
Wiring & Connector to the wiper motor Connector on the motor
When the connector and wiring burned on my 2013 cooling fans they simply cut back to where there was good wiring and then spliced in new wiring and a connector No need to replace all the wiring.
