HELP
Old Nov 27, 2005 | 01:03 PM
MustangNick16's Avatar
MustangNick16
Default HELP
well after my accidnet last night my raidiator has finished draining. i went to the store and bought a radiator leak stop, (as a temporary fix to get it to the dealer) here is my ? how do you get the face plate off that is covering the top of the raidiator and grill. And it say u have to pur it directly in the raidiator and all i see is raidiator hold downs on both sides but no cap. It has thes tab things and i dont want to bustany more things[&o][&o][&o]
PS how do u operate the hose clamps wat kind of tool do i need to make this work thanks
Old Nov 27, 2005 | 01:58 PM
Torch_Vert's Avatar
Torch_Vert
Default RE: HELP
Dude, your radiator is leaking all over the place and your suspension is wobbly. It's time to call a tow truck to move it to the dealer rather than risk more damage. If you crack the block running out of coolant on the way because you're driving with a damaged radiator, good luck getting that covered under warranty.
And if you're worried about $ for the tow, call your dealer. Some of them will pick up a car they're going to be working on either free or at reduced rates.
