tuning question
Hi
I'm new to this forum. I have a 2005 red fire V6 mustang. The only upgrades that I have done to it is duel magnaflow
exhaust, and tinted windos. Ok to my question, when I got my exhaust installed a worker at the shop said that if I wanted
to install new headers, or if I wanted to install a cool air intake system I would have to dyno my car, that reguler hand held tuners
would not do the job. Is this true. Any info will be apreciated Thanks.
I think he meant tune not "dyno", and no, you only have to tune your cars with certain cold air intake systems. Headers will not require a tune, unless theres something I dont know. Hope this helps.
Thanks for the info, it helped alot. the exact words the guy used were "with the exhaust set up that I put on. if you want any other
perfomanc upgrades like headers, or a cool air intake you will have to dyno your car." Thats why I put dyno on the above post.
just to let you know I put true duels with an "X" pipe, two Bullet Magnaflow mufflers, and two 4" tips
the gains wont be all that different with just a custom tune from somewehre like brenspeed (they make a custom tune for parts they sell, as long as you buy the tuner from them) vs a dyno-
however, the dyno WILL give you better results, just not that much
Thanks for all the info everyone. The guy I talked to also said that if I use a hand held tuner that it will not do the job, that after
a few thousand miles with the extra HP it would start wearing my motor down. In your opinion how well do these tuners work.
Thanks in advance.
Thanks in advance.
ORIGINAL: youngmustanger
Thanks in advance.
Thanks in advance.
A tuner is required if you go from 16 to say 18 inch wheels, cause you need to fix the tire revs. If you change out the gears, you will need it to change the gear ratio. For a CAI/Exhaust, you can get by without it, but for maximum gain it is required to change the air flow.
If you don't want to mess with the tuner go with a exhaust, and perhaps a CAI that dosent require a tune, like the AFE or K&N.
Good luck.
OK, i really didnt want to make a whole new post about this so i figured i would ask her. Im ordering my x cal 2 tonight and i am just wondering when they say that you can change your partial throttle shift firmness and wot shift firmness what is this actually doing. Like would i chirp tires or something or just shift faster as if a manual. and can this damage my car
well you could tune it to do either (i dont know why you would want to chirp your tires) but i know a lot of people change shift points to take advantage of the higher rpm's
there is actually a guy in the 05-06 4.6 section that swears he will beat any manual with his tuned auto (and i don't doubt him)
well i guess this could damage your car if you made your shift points extremely high leaving your car in really high rpm's for long periods of time
ORIGINAL: chrisc
