LOWERING SPRINGS
Old Feb 14, 2006 | 09:12 PM
nicarc369's Avatar
nicarc369
Default LOWERING SPRINGS
The springs are my quick fix to not buying wheels (don't want to spend $1500 on the wheels I want just yet) but I don't like the big gap between the wheel and fender. What is the best brand and how low should I go to take a decent chunk out of the gap?
Old Feb 15, 2006 | 12:20 AM
LesteR723's Avatar
LesteR723
Default RE: LOWERING SPRINGS
Road Magnets:
they're not out just yet, i'm using their prototype, which was developed for MY car, and i have the only set in the world. I'll let ya know when you can get them- if you want
Old Feb 15, 2006 | 11:43 PM
Torkfastback's Avatar
Torkfastback
I went with Eibach Pro line and the hieght is perfect. Used $30 camber bolts for alignment...no problems.
Old Feb 16, 2006 | 03:31 AM
Sevalley's Avatar
Sevalley
whered u get the $30 camber bolts? did you do it all yourself?
Old Feb 17, 2006 | 12:17 AM
Torkfastback
You can get the bolts from O'Rielly's auto Parts. Yes, I did them myself in my carport with a jack and 2 jack stands. The front is a much bigger job than the back. Back is about a 1 hour job...no problem. The front is easy too, but it requires renting a spring compressor and taking off a lot of parts. Not hard, just time consuming. If you want to do it, let me know and I will be happy to give you my contact info for more details. You will need to have the front end alighned after your finshed.
Old Feb 18, 2006 | 07:20 PM
MRock's Avatar
MRock
Are they like the ones made by PROGRESS Technology? Looks like a bolt with a cam in the middle?
Old Feb 23, 2006 | 01:08 AM
Torkfastback
Yes.
Old Feb 23, 2006 | 07:38 PM
cstigger04's Avatar
cstigger04
LestR723, in those pictures is that your stock springs or the replacement ones? I ask because mine is stock and it looks like I have the same space between my tire and fender lips as you do.
Old Feb 23, 2006 | 10:41 PM
will_c's Avatar
will_c
WHY DO YOU HAVE TO REALIGN WHEN SIMPLY CHANGING THE SPRINGS/SUSPENSION????
Will someone please explain to me.
will
Old Feb 24, 2006 | 12:22 AM
afixer's Avatar
afixer
when you lower the suspention the toe and camber are off slightly mine was off by 3 degrees all better now
