197hp!!!!
Old Feb 22, 2006 | 12:20 AM
maagster's Avatar
maagster
Default 197hp!!!!
ok guys check it out check it out...... monday morning i head on over to this locale mustand shop "HP performance" to install my 3.73 gears and T-LOK. To make a long story short.... after a very long day.... i dyno my stang and came out with 197.24 hp and 230.40 trq. .... this is SAE numbers... soo yea.. just thought i would let all yall know what's going down in florida!!! i'm waiting for my scanner to be fix so i can show yall the dyno sheet. payce out!!
Old Feb 23, 2006 | 01:10 AM
maagster's Avatar
maagster
Default RE: 197hp!!!!
alright.... like i said i just recently put in my gears along with my t-lok.. why is it that i'm smelling gear oil .... smells like crap... everytime i get on it... i smell it in my car... ALSO... why the heck can i not burn out anymore... i try it today and i'm chirpin' all over the place.. no traction whatsoever... my dash is shaking like crazy!!!!
Old Feb 23, 2006 | 11:30 AM
Philsy's Avatar
Philsy
I dont know about the smell ,I would check for leaks at the rear and at the wheels you might have an axel seal leaking on to your brakes or the input shaft of the rear might be leaking and driping on the exhaust justt enough for you to smell it.. I would check it out before driveing it any more...
and as far as your dash shaking while trying to do a burn out ,it sounds like you getting wheel hop now that they both are hooking up and yes you can hurt your car doing this the best way to get it in line is to start upgradeing your rear suspension...I have had this before in a few of my cars had to change over to polyurathane bushing and stiffer lower control arms to solve the problem..but it was worth it... good luck and hope this helps..
Old Feb 23, 2006 | 03:21 PM
maagster's Avatar
maagster
sweet... soo if i get lower control arms it will fix the wheel hopping?!?! what about upper control arms??? i went on v6mustangstuff and they had all these different types of gadgets and i don't noe which get buy?? help me out homie!!
Old Feb 23, 2006 | 03:33 PM
Philsy's Avatar
Philsy
I belive the lower ones are what you need but ask around Iam new to the whole FORD thing I am a die hard Chevy man myself I got this car more for my oldest son..
Old Feb 23, 2006 | 05:57 PM
justang05's Avatar
justang05
stangsuspension.com is a good place too. Lower control arms from steeda is what i would get.
RedStarBelgrade
Oct 29, 2008 09:41 AM
lilc1511
Jul 20, 2006 09:00 PM
