Nitto 555R's
Old Sep 6, 2007 | 10:28 PM
mitmaks's Avatar
mitmaks
Default Nitto 555R's
What pressure should I run at the track? I was recommended 20 psi, is that too high/low?
Old Sep 9, 2007 | 01:18 PM
HYPEracing's Avatar
HYPEracing
Default RE: Nitto 555R's
a good way to get the best air pressure for your car is set it at what you think is good, then spray a small strip of water in your drive way, and leave a nice dry spot directly after. then drive through the water, and measure the width of the wet tire track. add or remove pressure until you get the widest possible patch, with even pressure across the whole thing.
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Sep 17, 2015 07:32 PM
2007CalSpec
Sep 9, 2015 05:37 PM
Sep 8, 2015 11:50 AM
