S197 width and offset question
Old Dec 9, 2007 | 11:02 PM
Ford_Dude's Avatar
Ford_Dude
Default S197 width and offset question
I'm planning
295/50-17 rear and 245/60-17
what rim width and offset should I go with
and which tires (I hope nitto makes some in the rear size or I'll redo my calculations)
Old Dec 12, 2007 | 12:19 PM
Norm Peterson's Avatar
Norm Peterson
Default RE: S197 width and offset question
Are you sure that you want tires that are over 28" tall?
FWIW, I only get one hit on your two sizes combined at Tire Rack (245/60-17).
Norm
Old Dec 12, 2007 | 02:16 PM
Ford_Dude's Avatar
Ford_Dude
what I want is 295 rear and 235~255 front
and for the front and rear to have very close diameter
and I want to do it on 17's
Old Dec 12, 2007 | 03:04 PM
Norm Peterson
Tough order.
I can find either 245/50-17 or 255/50-17, both at about 27" tall (same as OE) with no close rear match in 17". I am assuming that you don't want the front tires to be visibly larger diameter than the rears.
Also 245/45-17 front with 285/40-17 rear at 25.67" and 25.95" tall.
Couldn't find any 295/xx-17's except in competition models (295/35-17 at 25.3", 295/40 at 26.1").
Norm
Old Dec 12, 2007 | 08:06 PM
Ford_Dude's Avatar
Ford_Dude
It looks like I'll have to step up to 18's
can you suggest a set?
Old Dec 13, 2007 | 08:07 AM
Norm Peterson
That 295 number is still a sticking point - you'd probably want a 295/40, but all I can find is 295/45 (28.4") and 295/35 (26.1"). I only looked at Tire Rack this time, but if you can't find a given size there now you may have trouble finding it at all next time around.
Something like the GT500 setup (255/45 & 285/40) except on 9" front and 10" rear wheels may give you the look you're after. 10.5" rears will make the 285's measure a little wider still if the available offsets will let that fit. Maybe 245/45's up front on 18 x 8.5's if you're looking for a little more of a "big-n-little" look (there's not much diameter difference between 245/45 and 255/45).
Norm
Old Dec 13, 2007 | 08:45 PM
Ford_Dude's Avatar
Ford_Dude
well I want to go the widest possible
and from what I've read its hard to fit wider than 295 rear on the s197
and I know if I compromise on the size I'll be less satisfied
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
