Do they need a balance?
Old Apr 8, 2008 | 10:47 AM
sp44's Avatar
sp44
Default Do they need a balance?
I bought some used oem (150 mile rims and tires on ebay). Do I need to have them rebalanced on my car after I put them on?
Old Apr 8, 2008 | 12:02 PM
Stoenr's Avatar
Stoenr
Default RE: Do they need a balance?
Shouldnt. Im assuming they were never removed from the wheel. check for wheel weights on the rim
Old Apr 8, 2008 | 04:49 PM
sp44's Avatar
sp44
No, never removed, they do have wheel weights. No Tire Pressure Sensors though. Also can I use the same lug nuts? I have 17" Bullets now, going to 18" Fan Blades.
Old Apr 8, 2008 | 06:34 PM
Stoenr's Avatar
Stoenr
Just swap em out. lug nuts work for both. I use to swap the same setup for winter/summer
Old Apr 8, 2008 | 07:29 PM
sp44's Avatar
sp44
Can I borrow that lift?
Old Apr 8, 2008 | 07:48 PM
Stoenr's Avatar
Stoenr
Lol. One of the benefits of my job.
Old Apr 8, 2008 | 10:40 PM
sp44's Avatar
sp44
Any idea what wheels would have more weights when put on the car? Two have only a couple weights and two have about double that.
Old Apr 8, 2008 | 11:58 PM
Stoenr's Avatar
Stoenr
Thats pretty much the norm. I would say as long as not more than 2.5 oz in a size. I have balanced wheel assemblies that have not required any weight.
If there is more than 2.5 oz of weight "I" would break the tire down and turn 180 degrees on the rim and rebalance.
Im sure yours are fine.
Old Apr 9, 2008 | 09:49 AM
sp44's Avatar
sp44
So it doesn't matter what wheel has more weight? Wheels with more weight go in front/back? Seemed the ones on the car had more weight in back so that's where I put the new ones with more weight.
Old Apr 9, 2008 | 01:56 PM
Stoenr's Avatar
Stoenr
Dont matter. going to rotate them eventually anyway
