Help PLEASE
Old Jun 16, 2008 | 07:37 PM
BeachBlv's Avatar
BeachBlv
Default Help PLEASE
I need help. I need to know If a set of GFG Hollywood style rims in 20"x10.5" size, with 315/35ZR20's will will be able to get stuffed under the *** end of a lowered 2005 V6 stang. Thanks.
Old Jun 16, 2008 | 08:37 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: Help PLEASE
Is this a pic of a car that already has this size wheel/tire combo? Those look like some serious meats under there!
I know a 305 on a 10' rim works fine on a Saleen, and it has over a 1.5' drop on rear. I have never seen 10.5's on an S197, but figure it will work. I am going 11's on my New Edge and going to run 315/30's and your car has more fender well room than my car. I think with the right off-set, you will be fine.
You need to do your research here and find someone who has this set-up and what the off-set and diameter of tireis. You may think about a 18' or 19' wheel as you will have more options for tire sizes and profiles as well as smaller overall diameter to aid in clearance especially since it is lowered.
Jazzer
Old Jun 16, 2008 | 09:03 PM
BeachBlv's Avatar
BeachBlv
yeah thats my car in my sig. Its running 20"x10"s in the back but I dont remember the tire size off hand. This is for my buddy, and his torch red V6 coupe. Hes getting the same wheels that are on the Street scene Mustang. Im quite jealous thanks for you help.
Old Jun 17, 2008 | 07:17 AM
Jazzer The Cat
Retired Moderator
The best way at this point, is to confirm clearance of YOUR car and you can determine if/how 10.5's will fit on your buddy's car.
Park your car going up a steep driveway at a 45° angle so the axle is heavily articulated. Measure clearance at all points where tire is close to fender, suspension components, exhaust etc. You will be able to see how much wider/taller a tire you can install on his car without rubbing.
BTW, your car is sharp
Good luck. Jazzer
Old Jun 18, 2008 | 10:37 AM
BeachBlv's Avatar
BeachBlv
thank you so much for your help man. thats what I will do.
