20" Wheel & Tire Fitment
Will these fit with no rubbing, etc.? I know they are 1.6" taller than stock.
Front
20x9 (42mm offset) with 275/40ZR20
Rear
20x10.5 (56mm offset) with 315/35ZR20
Martin
Front
Rear
Martin
I think the frontrimswill be fine, but unsure of rears. I think you should go 35 & 30 series tires,if possible. This will help with clearance and may not mess up your speedo accuracy. Saleenruns 275/35/20's (f) and275/40/20's(r). Many install 305/35's on the stock 10's and don't have an issue.
Best way to figure this out, since I HATE using off-set measurements, is back-space. Go ***HERE*** and measure the back-spacing for existing wheels and then the 10.5's. When you have these measurements, I will ask you to do some more measuring. Where did you find the wheels? Did you see a fitment guide saying it would work on your car?
Jazzer
Jazzer
Sep 16, 2015 07:53 PM
Sep 8, 2015 11:50 AM
