07 on 95
Old Aug 9, 2008 | 02:08 AM
D8Z's Avatar
D8Z
Default 07 on 95
Please can someone tell me if 17x8 2007 GT wheels will fit on a 1995 GT? Thanks
Old Aug 9, 2008 | 06:48 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Default RE: '07 on '95
Yes, they will.
They will set in a little farther, 1/2' or so,as the off-set of the S197 ('05+ Stangs) is greater than the SN95 ('94~'98 Stangs). If your current wheels are 7' wide, the face of the wheel will probably be in the same location relative to the outside of the fender.
To confirm this, measure the back-space ***HERE*** of both wheels and do the math.
Jazzer
Old Aug 9, 2008 | 03:19 PM
D8Z's Avatar
D8Z
Thanks.
I have just bought this vehicle. The present wheels on it are some ugly 20x8.5
Would 245/45R17 be the idel size tyres for the 17x8 rims?
Old Aug 10, 2008 | 11:29 AM
Jazzer The Cat
Retired Moderator
There were 20' wheels on the '95 you just bought?
I would think there would have been a least a bit of rubbing, especially on the fronts. 245/45/17's are a good fit for an 8' wheel. I ran 245/40/17's on my '85 Stang and was a pretty firm ride due to overly-aggressive shocks and lower series tires.
Jazzer
Old Aug 10, 2008 | 07:11 PM
D8Z's Avatar
D8Z
255/35/20 tyres. No rubbing, just plenty of ugly.
Link to wheel pic:
http://www.magandturbo.com/pages/whe...aid=-530444926
Old Aug 10, 2008 | 07:19 PM
Jazzer The Cat
Retired Moderator
I am surprised as I know of a New Edge running 20's up front and rubs quite a bit.
Jazzer
Last edited by Jazzer The Cat; Aug 20, 2008 at 09:55 AM. Reason: Updatin' some smileys
Old Aug 14, 2008 | 02:23 AM
D8Z's Avatar
D8Z
Default Jazzer, hope you see this
Jazzer, I have just realized that the 07 wheels have 45 offset. You said they would sit in further than the stockers, but will they fit without the need for spacers?
Old Aug 14, 2008 | 09:30 AM
Jazzer The Cat
Retired Moderator
I think the off-set of the SN95 Stangs is +35mm up front. That means your NEW wheel will sit inward 10mm (or about 3/8") so see no need for any spacers as you will have this additional room under there.
Install them and completely turn the wheel both directions and measure clearances PRIOR to driving car to make sure you don't hit brake lines, fender, liner and such.
Jazzer
Last edited by Jazzer The Cat; Aug 21, 2008 at 07:46 AM. Reason: fixing default e-mail notification
Old Aug 14, 2008 | 02:08 PM
D8Z's Avatar
D8Z
Thanks Jazzer, I really appreciate your help.
Old Aug 20, 2008 | 09:36 AM
95redv6stang's Avatar
95redv6stang
I run 245/40-17 on my 95 and they ride fine for me. You dont want to go any lower than 40 series in my opinion.
And i attempted to install some R1 wheels and had problems with the wheels rubbing the front caliber (due to the offset)
But with the 07 GT wheels you should be fine.
Jazzer is always on top of things. lol.
