Question about possible rubbing?
Old Nov 4, 2008 | 06:07 PM
darkmach1's Avatar
darkmach1
Default Question about possible rubbing?
I recently installed 18x10.5 with 295-35-18s (+27mm with 6.9" backspacing) out back and today I removed the passenger side rear wheel and noticed some scratches around the rim where it meets the tire's sidewall, which I don't recall seeing upon delivery. I don't really see anything that might be causing it, there are no scratches anywhere in the wheel well so I came on here to ask the experienced people. Should I get some spacers or not worry about it.
Old Nov 4, 2008 | 06:58 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
When I was running 10.5"s, I had 6~7/8" backspace and was fine.
Would be VERY strange to have damage to wheels and no signs on tire. I would also expect you to have heard something. Take a close look and confirm you don't have some bracket out of place or bent causing contact.
Do you have some pics?
Jazzer
Old Nov 4, 2008 | 07:44 PM
darkmach1's Avatar
darkmach1
Jazzer
yea its very weird, I looked around for about 10 minutes and couldn't find anything. I imagine its gotta be a metal piece to scratch like that, but everything is painted black and there's no sign of rubbing even on the exhaust. I heard what sounded like a very low rub between metals when driving but the wheels have a couple of scratches its not all the way around.
Old Nov 4, 2008 | 09:00 PM
Jazzer The Cat
Retired Moderator
If the scratch is NOT all the way around in a pattern, then a couple things may have happened.
1. Tire installer scratched them somehow during their work
2. You may have hit a lug-bolt during install yourself
3. You may not have noticed the scratches when you purchased them
4. Mini Me crawled under your ride with a screwdriver
I vote 4
Jazzer
Old Nov 5, 2008 | 08:21 AM
darkmach1's Avatar
darkmach1
I vote 4
Jazzer
LOL at #4. I guess I'll keep an eye on it, I'll remove the wheel again in a week of so and take a look. The tires came already installed on the rim and I installed them on the car myself. If I see it get any worse then I will have to gewt some spacers.
Old Nov 5, 2008 | 09:38 AM
Jazzer The Cat
Retired Moderator
If you go spacers, you will need to replace lugs to go over 1/4" wide, IMO. I have 1/2" spacers installed and run extra-long/strong lugs to remain safe.
Jazzer
Old Nov 5, 2008 | 01:26 PM
darkmach1's Avatar
darkmach1
Jazzer
so if I go over a 1/4" I'll have to replace the lugs, damn I hope I'm not rubbing LOL.
Old Nov 5, 2008 | 06:51 PM
darkmach1's Avatar
darkmach1
Jazzer, I forgot to mention that I didn't do an alignment on the car, do you think that might help?? The car is not lowered.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
