Some help please.....
Old Nov 7, 2008 | 10:24 PM
DeuceJuggalo's Avatar
DeuceJuggalo
Question Some help please.....
Alright here's my delimma. I'm not really a wheel and tire guy. Never really took the time to understand it. I own a 1990 Mustang GT. It's lowered with 17'' rims and low profile tires right now. I'm looking at getting a different set of tire and rims for the winter, and I know someone that will give me some 14'' steel wheels. the stock tire size for the car is 225/60 15. If I took the rims and just bought tires what size would they need to be to make sure everything clears and is still driveable?? Any information would greatly help.
Old Nov 8, 2008 | 08:06 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
Well, a '90 LX model had 195/75/14"s. So the only issue with fitment on a GT would be possibly larger brakes. I had an '85 GT and recall the brakes to be pretty small, but this NEEDS to be confirmed prior to attempting 14" wheels.
I need more information to tell you if they would fit:
1. How wide are the wheels? > 7" would be fine
2. What is the off-set of wheels? > between 0 & -22mm would be fine
3. What is the bolt pattern of the wheels? > 4x108mm
4. What is diameter of snow tire? > 25.6" is stock tire diameter
Can you borrow the wheels and see if they fit OK? This would confirm if the rim will clear the brake calipers/rotors. You could then compare the back-space of current wheels with the new 14" ones. Go ***HERE*** to see how this is done and let us know what you find.
We need information.....IN formation
Jazzer
SJ Stang
Oct 19, 2010 12:48 PM
runfox
AmericanMuscle.com
Apr 12, 2010 05:29 PM
cali_styleavl
Sep 25, 2009 02:52 PM
Andover Stang
Aug 18, 2009 05:40 PM
joaquinGT
20
Feb 14, 2009 06:20 AM
