correct backspacing for a fox?
Old Mar 24, 2009 | 09:40 AM
blk89lx's Avatar
blk89lx
Default correct backspacing for a fox?
im looking to purchase a set of american racing torqlite wheels for my 91. specs are front 17x7 with 4" bs and rears are 17x8 with 4.5" bs. can anyone tell me if that would be correct bs for a fox?
Old Mar 24, 2009 | 03:02 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
17"x9" wheels at American Muscle with a 5.8" back-space.
17"x8" wheels at American Muscle with a 5.2" back-space.
16"x7" wheels at American Muscle with a 4.8" back-space.
Your clearance will not be an issue with wheels mentioned
Jazzer
Old Mar 24, 2009 | 04:45 PM
blk89lx's Avatar
blk89lx
i dont understand how that was suppose to help can you explain?
Old Mar 24, 2009 | 05:15 PM
1slow67's Avatar
1slow67
ROTM Moderator
Shows you backspacing you could use without any problems.
Old Mar 24, 2009 | 07:36 PM
Jazzer The Cat
Retired Moderator
Sorry, maybe wasn't too clear, but BA is correct
All the wheels I listed were for a Fox Body Stang, and have a larger back-space than the ones you listed. Since you can put a 9" wheel I listed on your ride, you can easily run the 7"s & 8"s.
Jazzer
Old Mar 24, 2009 | 10:54 PM
blk89lx's Avatar
blk89lx
so that 4" bs in the front and the 4.5" bs in the rear will work? i dont want the wheels to stick out or be too sucked in the wheel wells either
Old Mar 25, 2009 | 06:02 AM
Jazzer The Cat
Retired Moderator
I see them as a bit outward toward the fender, but certainly not beyond.
Head over to ***THIS*** site and will help with some of this info. I also suggest you remove one of your current wheels and measure back-space. You will be able to use the dimensions of your existing wheels to do the math on how NEW wheels will fit your ride. This is not difficult, just takes a little time.
HTH
Jazzer
Jan 21, 2016 01:30 PM
UrS4
Oct 3, 2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
RCS02v6
Sep 29, 2015 01:46 PM
