offset question
Old Apr 9, 2009 | 05:06 PM
2011Black5.0's Avatar
2011Black5.0
Default offset question
I bent a wheel so I have to order a new one, but the reverb has been discontinued and I cant find any used ones in my size. I found the 18x8.5 with a 45mm offset and was wondering, would it be possible to take an 18x8.5 and widen it to 18x9.5 then fix the offset? Could I add a spacer or what? Any help appreciated
Old Apr 9, 2009 | 05:31 PM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
What you are proposing, can be done, but would be hard to justify cost.
I myself have sent a set of wheels to Weldcraft for widening, as I did a LOT of research and found them to be the best. The cost to have this done a year ago was $225 per wheel (reguardless of how wide/narrow it was made) and shipping both directions would be extra.
As for spacer, I would ONLY do such a thing with longer studs as I have myself running 1/2" out back.
Contact Weldcraft and see what they say about off-set "adjustment"
Jazzer
Nice pic of you and your ride, BTW
Old Apr 9, 2009 | 07:18 PM
2011Black5.0
Jazzer
Lol thanks, thats funny I did a google search and had sent them an email earlier, still waiting to hear back from them. Cost is the least of my concerns because I cant find the right wheel so I just have to take the right diameter and widen it and just adjust the offset. Thanks for the info Jazzer , I was worried as to wether or not they would be able to do it.
Old Apr 10, 2009 | 11:14 AM
2011Black5.0
Damn I guess they cant do the offset adjustment:
Hello,
Can't do anything about the offset .... if we add to the inside of the wheel that will increase the back space as well.
So if we add the 1 inch to the inside it will not effect the front offset.
Your looking at $215.00 per wheel to do and three to four week turn around time.
Thanks
James
Now i dont know what to do
Old Apr 10, 2009 | 09:14 PM
Jazzer The Cat
Retired Moderator
If you widen wheel 1", how much of a spacer will you THEN need to be correct?
Jazzer
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
