Tire Question
Old Dec 30, 2009 | 09:49 PM
1slow67's Avatar
1slow67
ROTM Moderator
Default Tire Question
I just recieved my new set of rims for my 1967 Mustang. Now I am looking for some tires to put on them. They are 15x7 for the front and 15x8 for the rear. I am either going with a 205 or 225 for the front tire, but the back isn't decided. I am thinking about getting a set of 255s for the rear, but I don't know if they will fit. So my question is will a 255 size tire would fit good on a 8" rims or would I be better off sticking with a 245 or 235. Also would a 225 tire fit a 8" rim or is that just too small? I don't want a big bulge and I definitely don't want to stretch the tires.
Old Dec 31, 2009 | 08:50 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
On a 15"x8" wheel, I would imagine that most 255's will be rated to fit (generally, a 245 is max). As for clearance, it is going to be probably 1.5" wider than the outside of the wheel itself, so clearance depends on the available room. I cannot tell you much about clearance on your ride and even less without knowing the off-set of your wheels. A 225 will fit on an 8" wheel, but agree it will run a bit on the "thin" side.
What are the actual sizes of the tires you are considering?
Jazzer
Old Dec 31, 2009 | 03:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
205/50/15 or 225/50/15 for the front
255/60/15, 225/50/15(only with 205 fronts) ,or 245/60/15 for the rear.
Old Dec 31, 2009 | 07:00 PM
Jazzer The Cat
Retired Moderator
The 255/60/15's are looking to run on a 5"~10" wheel, depending on the actual tire you choose... so I don't see any fitment issues there
As for the possible bulge, you will get more with the higher profile tire, so you need to do some research on how that tire actually "fits" an 8" wheel.
Jazzer
Old Jan 1, 2010 | 07:58 AM
1slow67's Avatar
1slow67
ROTM Moderator
Thanks
mtgldr
Feb 3, 2024 09:00 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
Sep 8, 2015 11:50 AM
raleigh05GTO
Sep 4, 2015 07:09 AM
