Mach 1 wheels...
Old Apr 6, 2010 | 07:41 AM
Synyster06Gates's Avatar
Synyster06Gates
Default Mach 1 wheels...
I just traded my old 97 Cobra wheels for a set of Mach 1 wheels. Few questions...
Are they still 17x8? If not, will I be able to run a 275 out back? I want some thicker tires back there but I still wanna be safe.
If it makes any difference, the tires would be 275/40-17 Sumitomo HTRZ II. Had them in 245s on my Cobras and I liked them.
Old Apr 6, 2010 | 09:12 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
This depends on the year of Cobra wheels in which you buy. Some are 8" and the later ones are 9". You need a 9" wheel to safely run a 275 tire, otherwise you are going to need to stick with 245's.
Jazzer
Old Apr 6, 2010 | 10:20 AM
Synyster06Gates
I have Mach 1 wheels now, I sold my old 97 Cobras.
Old Apr 6, 2010 | 11:09 AM
2003redmach1's Avatar
2003redmach1
Im pretty sure the 2003-04 mach 1 rims are 17x9
Old Apr 6, 2010 | 11:10 AM
Jazzer The Cat
Retired Moderator
Ooops.... I think the Mach 1 wheels are 8", but not positive. If they do not have tires mounted on them, you can measure from the INSIDE of each lip of rim across the middle and will be 8" or 9".
Jazzer
Old Apr 6, 2010 | 11:12 AM
Jazzer The Cat
Retired Moderator
2003redmach.... what size tires are you running? If they are OEM, than I can tell by the size.
Jazzer
Old Apr 6, 2010 | 11:26 AM
Synyster06Gates
They do have tires mounted on them. They are all 245/45 at the moment but I want something a little bigger for the rear.
Old Apr 6, 2010 | 08:36 PM
Jazzer The Cat
Retired Moderator
If they have a 245 and are the ORIGINAL tires, they are 8" wheels. If you can look from directly behind the tire and NOT see any of the wheel itself, you have an 8" wheel for sure and a 245 is max you will properly fit.
If you REALLY want to run these wheels with wider tires, you can send them off to Weldcraft Wheels to have them widened, but will cost you some $$$ to do so. If interested, I can give you more detail via PM as I have done this on two different sets of wheels.
Jazzer
1BAD3V
Tennessee Regional Chapter
Oct 6, 2016 12:12 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
Sixer4Life
Sep 29, 2015 07:03 PM
1BAD3V
Indiana Regional Section
Sep 26, 2015 09:03 AM
