Question about rims need help
I'm looking to buy a set of rims from a 1988 Mustang GT and need to know the size of lug holes. These came stock he said. I need a set to fit 4X4.25 to fit a project I'm doing. I need help to see if these are 4.25 or 4.50 they are 15 inch tires.
The project I'm doing calls for 74-78 Mustang, 75-80 pinto, or 75-80 bobcat. Any help on this would be greatly appreciated. They also tell me that honda 4 lug rims are the same, But I don't know.. Thanks Garyy
Lots of questions here, but off-set differences are probably going to be your enemy here
Even if the lug-spacing is the same on all those rides, they may not fit due to width of wheel and back-space measurements. 4x4.25" is the correct pattern for a '79~'93 Stang, but no difference in the diameter of the lug-holes to create a problem.
A Honda wheel will likely not work, as all of them in which I know are FWD and usually need a specialty designed wheel to clear drive components.
Good luck
Jazzer
Good luck
Jazzer
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
