Dry rot question
Old Sep 8, 2012 | 11:12 PM
Armydad's Avatar
Armydad
Default Dry rot question
Hey,
I picked up some BF Goodrich KDWs' and they have been sitting on a rack in my garage for a couple years. How long can a tire sit before dry rot becomes an issue? They still look ok but they are not on a vehicle under the weight pressure, so I'm not sure if that means anything. Do you guys think they will still be useable?
Old Sep 9, 2012 | 07:11 AM
Jazzer The Cat's Avatar
Jazzer The Cat
Retired Moderator
So long as they have not been exposed to serious moisture and weather, they should be fine. When I store my Summer tires/wheels, I let them down to about 18 PSI and put them in the storage shed. Now, this is not two years, but being uninstalled is ideal.
Take a close look at them and bend them around. Look for cracks or anything like that. If they look good, mount them up and go rip da corners already
Jazzer
Old Sep 10, 2012 | 03:57 PM
TRexGAWD's Avatar
TRexGAWD
Pretty much what Jazzer said is true.. Being that they had no load that helps a lot, just inspect them close for cracks and such. I really don't think there will be any problem after a couple years... If you're really worried, mount them on a rim, pressurize them and check for any leaks (soapy water)..
Old Sep 10, 2012 | 04:06 PM
slipperman's Avatar
slipperman
Something else to think about is Ozone.
If you store them where electric motors are running (refrigerators, furnace, etc.) then the ozone produced will accelerate the rot.
b8checker
Oct 8, 2015 12:55 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
b8checker
Sep 30, 2015 07:11 AM
