footwell lights?
Old 08-07-2010, 03:58 PM
ejanderson05gt
ejanderson05gt's Avatar
Do this: http://www.cherod.com/mustang/HowTo/footwellLights.htm
Use the flexible LED strips from Advance Auto, think they're about $25 bucks. ^^^ This procedure will only turn the lights on when the doors open.
ejanderson05gt is offline
Old 08-07-2010, 04:35 PM
157dB
Cut & Paste Expert
157dB's Avatar
^^^^ best way.
I did it first mod and have not looked back since.
Lights up the footwells great.
Wal-Marts for the LED lights in the marine section.
$10 each.
Zip tie them into place well under the dash but
pointing downward.
157dB is offline
Old 08-08-2010, 02:25 AM
Torch Red GT
Torch Red GT's Avatar
Originally Posted by bxsicecold
I used this kit in mine. Wire it into the fuse box with any fuse that is only hot when the car is in acc or run that way you dont leave them on and kill your battery. I put two under each side off the dash and one under each seat facing the rear. Comes with a wireless remoteto control the patterns. Doesnt "beat to the music" but it does have plenty of different patterns/colors. Works great and cant beat the price.
http://www.ledunderbody.com/Million-...hting-Kit.aspx
Can you adjust the brightness on that kit? Id want a kit that lets you adjust the brightness so it would look like the oem ambient lighting.
Torch Red GT is offline
Old 08-08-2010, 09:09 AM
2007bluestang
2007bluestang's Avatar
i dont wanna deal with all that wiring and stuff because if i screw anything up my parents will be PISSED..im just gunna pay some money for someone else to do it
2007bluestang is offline
Old 08-08-2010, 09:23 AM
TPony
TPony's Avatar
http://www.mossmuscle.com/Shop/ViewP...eIndexID=84719
Got mine from Moss...I used "T" taps, per instructions and connected them so they light up when I open the doors or use interior lighting. Yes, you can do it with a friend. BTW, they are not as bright as the picture on the website leads you to believe.
TPony is offline
Old 08-08-2010, 02:58 PM
bxsicecold
bxsicecold's Avatar
No you cant adjust the brightness, but its not blinding by any means. Its not near as bright as the website video shows. I hardly even notice it since I've had it for so long now. I get complements on it all the time. I will try and get some pictures of it at night.
bxsicecold is offline
Old 08-08-2010, 03:03 PM
bxsicecold
bxsicecold's Avatar
Its not that dificult to do. One wire runs to a fuse for power. Another wire to the chassis for a ground. Everything else is just plug ins for the kit. The worst thing you could do is blow a fuse. If you a want to waste money to pay someone else to hook up 2 wires go ahead, but its easily done yourself.
Old 08-08-2010, 05:16 PM
Torch Red GT
What kind of tools do you need to do it all?
Old 08-08-2010, 05:29 PM
Torch Red GT
Old 08-09-2010, 05:28 PM
bxsicecold
bxsicecold's Avatar
1 Pair of wire strippers
A socket set for the ground
Zip Ties
Quick Reply: footwell lights?
