Style bar issue any help?
Old 05-27-2012, 07:40 AM
chrisdbassplayer
chrisdbassplayer's Avatar
Default Style bar issue any help?
hey I just installed a MMD Style bar a couple weeks ago. On vacation I noticed a little ripple in the outer covering I smoothed it back out thinking maybe it was a small glue issue. A day later this is what it looked like in the picture and the next day the whole thing had came loose. Anyone else have any problems like this? american muscle is replacing it but I wondered if anyone else had these issues or if I should expect to see the same results again with the new one?
chrisdbassplayer is offline
Old 05-27-2012, 08:21 AM
Torch_Vert
Torch_Vert's Avatar
It also looks like it's not sitting flat on top of the trim panel (see the gap towards the back?)
Apparently there's a reason the CDC bars cost more
Hope AM gets it sorted out for you quick.
Torch_Vert is offline
Old 05-27-2012, 09:27 AM
chrisdbassplayer
I had my suspicions that the bar may be bent a little when I found a huge foot print on the box. The other side looked perfect hopefully it will get here better condition than last time, the packaging was not good. Ya this bar is a little cheaper but still for nearly 300$ you would expect better.
Old 05-27-2012, 10:05 AM
Torch_Vert
Torch_Vert's Avatar
I don't disagree, you should expect much better than the covering peeling like that. Hopefully the replacement is good.
Old 05-27-2012, 01:42 PM
chrisdbassplayer
Thanks Torch, I never saw one single review that said it had peeling problems, there were a few that said fitment wasnt perfect. the directons to put this on were terrible I couldnt believe they wanted me to use a 2" hole saw for an 1 1/2" cut and most of the tools they suggest arent the right sizes... wow
Old 09-10-2012, 08:50 PM
mylittlepony911
mylittlepony911's Avatar
Did the replacement from AM do the same thingor are you happy with it now? I was just going to order this stying bar for my 2007 GT/CS - is it worth it?
mylittlepony911 is offline
Old 09-12-2012, 02:42 PM
Tommyc
Tommyc's Avatar
I got mine on ebay for around $80 because it was coming apart there too. A Little glue it looks like new and has for over a year.
Tommyc is offline
10-07-2015 07:02 PM
LivingInThePast
09-16-2015 12:20 PM
fastbackford351
09-12-2015 09:42 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Style bar issue any help?
