285/35/18 on 18x10 all the way around?
I bought two 18x10 deep dish Bullitt rims and put on 285/35's for the back. Once I had them on I would decide what to run up front. Looking at them it appears they would work up front as well. Or put those up front and go a little bigger on the back? I have a 1" drop with adjustable panhard.
I tramline pretty bad with 275's up front. I'd do 255's up front if I had to do it over again. Also, those 285/35/18's are about 2.25" smaller O.D. than stock and will not only throw your speedometer off by about 5 MPH (unless you have a handheld to change the revs per mile in the PCM) but also affects your overall gear ratio.
I went ahead on put them on up front. They look MUCH better up there than the back. I get a slight rub when wheel is turned all way. Now what to do with the back....thinking maybe a 20x10 with 285/35/20??
The rims do not come in 19", or that would be what I would do. I'm cool with 18's in the back as long as I can get a tire that won't look like a donut back there. Biggest the Michelin Sports come in is the 285/35/18. I could do a 245/45/18 which is taller but then the front is wider.
Dan04COBRA
09-30-2015 11:46 AM
01BlackGT
08-10-2005 03:34 PM
1slo302
04-03-2005 01:54 PM
